New interface
Conference papers
Scale-invariant shape features for recognition of object categories
Frédéric Jurie 1 Cordelia Schmid 1, *
* Corresponding author
1 LEAR - Learning and recognition in vision
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : We introduce a new class of distinguished regions based on detecting the most salient convex local arrangements of contours in the image. The regions are used in a similar way to the local interest points extracted from gray-level images, but they capture shape rather than texture. Local convexity is characterized by measuring the extent to which the detected image contours support circle or arc-like local structures at each position and scale in the image. Our saliency measure combines two cost functions defined on the tangential edges near the circle: a tangential-gradient energy term, and an entropy term that ensures local support from a wide range of angular positions around the circle. The detected regions are invariant to scale changes and rotations, and robust against clutter, occlusions and spurious edge detections. Experimental results show very good performance for both shape matching and recognition of object categories.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00548545
Contributor : THOTH Team Connect in order to contact the contributor
Submitted on : Monday, December 20, 2010 - 9:09:34 AM
Last modification on : Thursday, January 20, 2022 - 4:12:49 PM
Identifiers
  • HAL Id : inria-00548545, version 1
Collections
Citation
Frédéric Jurie, Cordelia Schmid. Scale-invariant shape features for recognition of object categories. International Conference on Computer Vision and Pattern Recognition (CVPR '04), Jun 2004, Washington, United States. pp.90--96. ⟨inria-00548545⟩
Share
Metrics
Record views
259
