Is that you? Metric learning approaches for face recognition, 2009. ,
Automatic face naming using caption-based supervision, 2008. ,
Solving the multi-instance problem with axis-parallel rectangles, 1997. ,
Learning a distance metric from multiinstance multi-label data, 2009. ,
