New interface
Conference papers
Margin-based discriminant dimensionality reduction for visual recognition
Hakan Cevikalp 1 Bill Triggs 2 Frédéric Jurie 3 Robi Polikar 4
2 AI - Artificial Intelligence
LJK - Laboratoire Jean Kuntzmann
3 Equipe Image - Laboratoire GREYC - UMR6072
GREYC - Groupe de Recherche en Informatique, Image et Instrumentation de Caen
Abstract : Nearest neighbour classifiers and related kernel methods often perform poorly in high dimensional problems because it is infeasible to include enough training samples to cover the class regions densely. In such cases, test samples often fall into gaps between training samples where the nearest neighbours are too distant to be good indicators of class membership. One solution is to project the data onto a discriminative lower dimensional subspace. We propose a gap-resistant nonparametric method for finding such subspaces: first the gaps are filled by building a convex model of the region spanned by each class - we test the affine and convex hulls and the bounding disk of the class training samples - then a set of highly discriminative directions is found by building and decomposing a scatter matrix of weighted displacement vectors from training examples to nearby rival class regions. The weights are chosen to focus attention on narrow margin cases while still allowing more diversity and hence more discriminability than the 1D linear Support Vector Machine (SVM) projection. Experimental results on several face and object recognition datasets show that the method finds effective projections, allowing simple classifiers such as nearest neighbours to work well in the low dimensional reduced space.
Document type :
Conference papers
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/inria-00548665
Contributor : THOTH Team Connect in order to contact the contributor
Submitted on : Thursday, January 6, 2011 - 2:55:04 PM
Last modification on : Saturday, June 25, 2022 - 9:46:35 AM
Long-term archiving on: : Monday, November 5, 2012 - 3:45:48 PM
File
margin_dimensionality_reductio...
Identifiers
Citation
Hakan Cevikalp, Bill Triggs, Frédéric Jurie, Robi Polikar. Margin-based discriminant dimensionality reduction for visual recognition. CVPR '08 - Conference on Computer Vision & Pattern Recognition, Jun 2008, Anchorage, United States. pp.1-8, ⟨10.1109/CVPR.2008.4587591⟩. ⟨inria-00548665⟩
Share
Metrics
Record views
169
Files downloads
162
