Learning Shape Segmentation Using Constrained Spectral Clustering and Probabilistic Label Transfer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a spectral learning approach to shape segmentation. The method is composed of a constrained spectral clustering algorithm that is used to supervise the segmentation of a shape from a training data set, followed by a probabilistic label transfer algorithm that is used to match two shapes and to transfer cluster labels from a training-shape to a test-shape. The novelty resides both in the use of the Laplacian embedding to propagate must-link and cannot-link constraints, and in the segmentation algorithm which is based on a learn, align, transfer, and classify paradigm. We compare the results obtained with our method with other constrained spectral clustering methods and we assess its performance based on ground-truth data.
SharmaLavanteHoraudECCV2010.pdf (631.78 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00549401 , version 1 (21-12-2010)
Avinash Sharma, Etienne von Lavante, Radu Horaud. Learning Shape Segmentation Using Constrained Spectral Clustering and Probabilistic Label Transfer. ECCV 2010 - European Conference on Computer Vision, Sep 2010, Heraklion, Greece. pp.743-756, ⟨10.1007/978-3-642-15555-0_54⟩. ⟨inria-00549401⟩
132 Consultations
228 Téléchargements
