Some randomized code constructions from group actions, IEEE Transactions on Information Theory, vol.52, issue.7, pp.3210-3219, 2006. ,
DOI : 10.1109/TIT.2006.876244
Algebraic Coding Theory, 1968. ,
DOI : 10.1142/9407
Algebraic Coding Theory, 1984. ,
DOI : 10.1142/9407
On the inherent intractability of certain coding problems (Corresp.), IEEE Transactions on Information Theory, vol.24, issue.3, pp.384-386, 1978. ,
DOI : 10.1109/TIT.1978.1055873
Semisimple cyclic and Abelian codes. II, Cybernetics, vol.3, issue.3, pp.17-23, 1967. ,
DOI : 10.1007/BF01119999
Theory and Practice of error Control Codes, 1983. ,
On a class of error correcting binary group codes, Information and Control, vol.3, issue.1, pp.68-79, 1960. ,
DOI : 10.1016/S0019-9958(60)90287-4
A proof of some properties of Reed-Muller codes by means of the normal basis theorem, Combinatorial mathematics and its applications ,
On the asymptotic badness of cyclic codes with block-lengths composed from a fixed set of prime factors, Lectures Notes in Computer Science, vol.357, pp.164-168, 1989. ,
DOI : 10.1007/3-540-51083-4_56
On repeated-root cyclic codes, IEEE Transactions on Information Theory, vol.37, issue.2, pp.337-342, 1991. ,
DOI : 10.1109/18.75249
Cyclic decoding procedures for Bose- Chaudhuri-Hocquenghem codes, IEEE Transactions on Information Theory, vol.10, issue.4, pp.357-363, 1964. ,
DOI : 10.1109/TIT.1964.1053699
On the key equation, IEEE Transactions on Information Theory, vol.41, issue.5, pp.1290-1302, 1995. ,
DOI : 10.1109/18.412677
On decoding BCH codes, IEEE Transactions on Information Theory, vol.11, issue.4, pp.549-557, 1965. ,
DOI : 10.1109/TIT.1965.1053825
Error Detecting and Error Correcting Codes, Bell System Technical Journal, vol.29, issue.2, pp.147-160, 1950. ,
DOI : 10.1002/j.1538-7305.1950.tb00463.x
URL : http://campus.unibo.it/10913/1/hamming1950.pdf
Codes correcteurs d'erreurs, Chiffres, vol.2, pp.147-156, 1959. ,
Coding Theory: The Essential, 1991. ,
Class of constructive asymptotically good algebraic codes, IEEE Transactions on Information Theory, vol.18, issue.5, pp.652-656, 1972. ,
DOI : 10.1109/TIT.1972.1054893
A Gilbert-Varshamov bound for quasi-cycle codes of rate 1/2 (Corresp.), IEEE Transactions on Information Theory, vol.20, issue.5, pp.679-679, 1974. ,
DOI : 10.1109/TIT.1974.1055262
An Introduction to Error-Correcting Codes, 1970. ,
Long BCH codes are bad, Information and Control, vol.11, issue.4, pp.445-451, 1967. ,
DOI : 10.1016/S0019-9958(67)90660-2
URL : http://doi.org/10.1016/s0019-9958(67)90660-2
Is the class of cyclic codes asymptotically good?, IEEE Transactions on Information Theory, vol.52, issue.2, pp.696-700, 2006. ,
DOI : 10.1109/TIT.2005.862123
The Theory of Error-Correcting Codes, 1977. ,
Shift-register synthesis and BCH decoding, IEEE Transactions on Information Theory, vol.15, issue.1, pp.122-127, 1969. ,
DOI : 10.1109/TIT.1969.1054260
Introduction to the theory of Error-Correcting codes, UIUC, 1982. ,
DOI : 10.1002/9781118032749
Huffman Handbook of coding theory, North-Holland, 1998. ,
Cyclic Error-Correcting Codes in Two Symbols " , Air Force Cambridge Research Center, 1957. ,
Polynomial Codes Over Certain Finite Fields, Journal of the Society for Industrial and Applied Mathematics, vol.8, issue.2, pp.300-304, 1960. ,
DOI : 10.1137/0108018
A Mathematical Theory of Communication, Bell System Technical Journal, vol.27, issue.3, pp.379-423, 1948. ,
DOI : 10.1002/j.1538-7305.1948.tb01338.x
Maximum distance<tex>q</tex>-nary codes, IEEE Transactions on Information Theory, vol.10, issue.2, pp.116-118, 1964. ,
DOI : 10.1109/TIT.1964.1053661
Transitive and self-dual codes attaining the Tsfasman-Vla/spl breve/dut$80-Zink bound, IEEE Transactions on Information Theory, vol.52, issue.5, pp.2218-2224, 2006. ,
DOI : 10.1109/TIT.2006.872986
A method for solving key equation for decoding goppa codes, Information and Control, vol.27, issue.1, pp.87-89, 1975. ,
DOI : 10.1016/S0019-9958(75)90090-X
Algorithmic complexity in coding theory and the minimum distance problem, Proceedings of the twenty-ninth annual ACM symposium on Theory of computing , STOC '97, pp.92-109, 1997. ,
DOI : 10.1145/258533.258559
