Y. Chitour, Time-varying high-gain observers for numerical differentiation, IEEE Transactions on Automatic Control, vol.47, issue.9, pp.1565-1569, 2002.
DOI : 10.1109/TAC.2002.802740
S. Ibrir, Linear time-derivative trackers, Automatica, vol.40, issue.3, pp.397-405, 2004.
DOI : 10.1016/j.automatica.2003.09.020
A. Levant, Higher-order sliding modes, differentiation and output-feedback control, International Journal of Control, vol.76, issue.9-10, pp.924-941, 2003.
DOI : 10.1080/0020717031000099029
C. K. Chen and J. H. Lee, Design of high-order digital differentiators using L/sub 1/ error criteria, IEEE Transactions on Circuits and Systems II: Analog and Digital Signal Processing, vol.42, issue.4, pp.287-291, 1995.
DOI : 10.1109/82.378044
C. M. Rader and L. B. Jackson, Approximating Noncausal IIR Digital Filters Having Arbitrary Poles, Including New Hilbert Transformer Designs, Via Forward/Backward Block Recursion, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.53, issue.12, pp.2779-2787, 2006.
DOI : 10.1109/TCSI.2006.883877
J. Cheng, Y. C. Hon, and Y. B. Wang, A numerical method for the discontinuous solutions of Abel integral equations, Inverse Problems and Spectral Theory, pp.233-243, 2004.
DOI : 10.1090/conm/348/06326
R. Gorenflo and S. Vessella, Abel integral equations: Analysis and applications, Lecture Notes in Mathematics, vol.1461, 1991.
DOI : 10.1007/BFb0084665
M. Hanke and O. Scherzer, Error Analysis of an Equation Error Method for the Identification of the Diffusion Coefficient in a Quasi-linear Parabolic Differential Equation, SIAM Journal on Applied Mathematics, vol.59, issue.3, pp.1012-1027, 1999.
DOI : 10.1137/S0036139997331628
Z. Wang and J. Liu, Identification of the pollution source from one-dimensional parabolic equation models, Applied Mathematics and Computation, vol.219, issue.8, 2008.
DOI : 10.1016/j.amc.2008.03.014
I. R. Khan and R. Ohba, New finite difference formulas for numerical differentiation, Journal of Computational and Applied Mathematics, vol.126, issue.1-2, pp.269-276, 2000.
DOI : 10.1016/S0377-0427(99)00358-1
R. Qu, A new approach to numerical differentiation and integration, Mathematical and Computer Modelling, vol.24, issue.10, pp.55-68, 1996.
DOI : 10.1016/S0895-7177(96)00164-1
A. G. Ramm and A. B. Smirnova, On stable numerical differentiation, Mathematics of Computation, vol.70, issue.235, pp.1131-1153, 2001.
DOI : 10.1090/S0025-5718-01-01307-2
D. N. , A. Schneider, and H. J. Reinhardt, Regularization of a non-characteristic Cauchy problem for a parabolic equation, Inverse Probl, vol.11, pp.1247-1264, 1995.
D. A. Murio, The Mollification Method and the Numerical Solution of Ill-Posed Problems, 1993.
DOI : 10.1002/9781118033210
D. A. Murio, C. E. Mejía, and S. Zhan, Discrete mollification and automatic numerical differentiation, Computers & Mathematics with Applications, vol.35, issue.5, pp.1-16, 1998.
DOI : 10.1016/S0898-1221(98)00001-7
URL : http://doi.org/10.1016/s0898-1221(98)00001-7
G. Nakamura, S. Wang, and Y. Wang, Numerical differentiation for the second order derivatives of functions of two variables, Journal of Computational and Applied Mathematics, vol.212, issue.2, pp.341-358, 2008.
DOI : 10.1016/j.cam.2006.11.035
T. Wei, Y. C. Hon, and Y. Wang, Reconstruction of numerical derivatives from scattered noisy data, Inverse Problems, vol.21, issue.2, pp.657-672, 2005.
DOI : 10.1088/0266-5611/21/2/013
Y. Wang, X. Jia, and J. Cheng, A numerical differentiation method and its application to reconstruction of discontinuity, Inverse Problems, vol.18, issue.6, pp.1461-1476, 2002.
DOI : 10.1088/0266-5611/18/6/301
M. Mboup, C. Join, and M. Fliess, Numerical differentiation with annihilators in noisy environment, Numerical Algorithms, vol.14, issue.12, pp.439-467, 2009.
DOI : 10.1007/s11075-008-9236-1
URL : https://hal.archives-ouvertes.fr/inria-00319240
M. Mboup, C. Join, and M. Fliess, A revised look at numerical differentiation with an application to nonlinear feedback control, 2007 Mediterranean Conference on Control & Automation, 2007.
DOI : 10.1109/MED.2007.4433728
URL : https://hal.archives-ouvertes.fr/inria-00142588
S. K. Rangarajana and S. P. Purushothaman, Lanczos??? generalized derivative for higher orders, Journal of Computational and Applied Mathematics, vol.177, issue.2, pp.461-465, 2005.
DOI : 10.1016/j.cam.2004.10.016
Z. Wang and R. Wen, Numerical differentiation for high orders by an integration method, Journal of Computational and Applied Mathematics, vol.234, issue.3, pp.941-948, 2010.
DOI : 10.1016/j.cam.2010.01.056
M. Fliess, C. Join, M. Mboup, and H. Sira-ramírez, Compression diff??rentielle de transitoires bruit??s, Comptes Rendus Mathematique, vol.339, issue.11, pp.821-826, 2004.
DOI : 10.1016/j.crma.2004.10.003
M. Fliess, Analyse non standard du bruit, Comptes Rendus Mathematique, vol.342, issue.10, pp.797-802, 2006.
DOI : 10.1016/j.crma.2006.02.037
URL : https://hal.archives-ouvertes.fr/inria-00001134
M. Fliess and H. Sira-ramírez, An algebraic framework for linear identification, ESAIM: Control, Optimisation and Calculus of Variations, vol.9, pp.151-168, 2003.
DOI : 10.1051/cocv:2003008
M. Fliess, M. Mboup, H. Mounier, and H. Sira-ramírez, Questioning some paradigms of signal processing via concrete examples, Algebraic Methods in Flatness, Signal Processing and State Estimation, pp.1-21, 2003.
URL : https://hal.archives-ouvertes.fr/inria-00001059
M. Mboup, Parameter estimation for signals described by differential equations, Applicable Analysis, vol.26, issue.1, pp.29-52, 2009.
DOI : 10.1109/MED.2008.4602161
D. Y. Liu, O. Gibaru, W. Perruquetti, M. Fliess, and M. Mboup, An error analysis in the algebraic estimation of a noisy sinusoidal signal, 2008 16th Mediterranean Conference on Control and Automation, 2008.
URL : https://hal.archives-ouvertes.fr/inria-00300234
M. Fliess, Critique du rapport signaì a bruit en communications numériques -Questioning the signal to noise ratio in digital communications, International Conference in Honor of Claude Lobry, pp.419-429, 2008.
G. Szegö, Orthogonal polynomials, 1967.
DOI : 10.1090/coll/023
N. Aronszajn, Theory of reproducing kernels, Transactions of the American Mathematical Society, vol.68, issue.3, pp.337-404, 1950.
DOI : 10.1090/S0002-9947-1950-0051437-7
S. Saitoh, Theory of reproducing kernels and its applications, Pitman Research Notes in Mathematics Longman Scientic & Technical, 1988.
E. I. Poffald, The Remainder in Taylor's Formula, The American Mathematical Monthly, vol.97, issue.3, pp.205-213, 1990.
DOI : 10.2307/2324685
A. Vladimir and . Zorich, Mathematical Analysis I, pp.219-232, 2004.
A. Ralston, A first course in numerical analysis, 1965.
