Focus+Context Visualization Techniques for Displaying Large Lists with Multiple Points of Interest on Small Tactile Screens
Abstract : This paper presents a focus+context visualization and interaction technique for displaying large lists on handheld devices. This technique has been specifically designed to fit the constraints of small tactile screens. Thanks to its spiral layout, it provides a global view of large lists on a limited amount of screen real-estate. It has also been designed to allow direct interaction with fingers. This technique proposes an alternative to multi-focus visualization, called "augmented context", where several objects of interest can be pointed up simultaneously. We propose two implementations of this approach that either use spatial or temporal composition. We conducted a controlled experiment that compares our approach to standard scrollable lists for a search task on a PDA phone. Results show that our technique significantly reduces the error rate (about 3.7 times lower) without loss of performance.
Type de document :
Communication dans un congrès
Interact 2007, 11th International Conference on Human-Computer Interaction, 2007, Rio De Janeiro, Brazil. Springer Verlag, pp.219-233, 2007, Lecture Notes in Computer Science
Liste complète des métadonnées
Littérature citée [26 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00550598
Contributeur : Stéphane Huot <>
Soumis le : mercredi 29 décembre 2010 - 01:14:24
Dernière modification le : lundi 4 mars 2019 - 17:00:05
Document(s) archivé(s) le : mercredi 30 mars 2011 - 03:19:56
Fichier
SnaiList-Interact2007.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00550598, version 1
Collections
Citation
Stéphane Huot, Eric Lecolinet. Focus+Context Visualization Techniques for Displaying Large Lists with Multiple Points of Interest on Small Tactile Screens. Interact 2007, 11th International Conference on Human-Computer Interaction, 2007, Rio De Janeiro, Brazil. Springer Verlag, pp.219-233, 2007, Lecture Notes in Computer Science. 〈inria-00550598〉
Métriques
Consultations de la notice
246
Téléchargements de fichiers
239
