Using Machine Learning to Focus Iterative Optimization, International Symposium on Code Generation and Optimization (CGO'06), 2006. ,
DOI : 10.1109/CGO.2006.37
Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., pp.7-16, 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
The Polyhedral Model Is More Widely Applicable Than You Think, Intl. Conf. on Compiler Construction (ETAPS CC'10), pp.283-303, 2010. ,
DOI : 10.1007/978-3-642-11970-5_16
URL : https://hal.archives-ouvertes.fr/inria-00551087
Automatic Transformations for Communication-Minimized Parallelization and Locality Optimization in the Polyhedral Model, International conference on Compiler Construction (ETAPS CC), 2008. ,
DOI : 10.1007/978-3-540-78791-4_9
A practical automatic polyhedral program optimization system, ACM SIGPLAN Conference on Programming Language Design and Implementation, 2008. ,
WEKA?experiences with a java opensource project, Journal of Machine Learning Research, vol.11, pp.2533-2541, 2010. ,
Automatic performance model construction for the fast software exploration of new hardware designs, Proceedings of the 2006 international conference on Compilers, architecture and synthesis for embedded systems , CASES '06, 2006. ,
DOI : 10.1145/1176760.1176765
Rapidly Selecting Good Compiler Optimizations using Performance Counters, International Symposium on Code Generation and Optimization (CGO'07), pp.185-197, 2007. ,
DOI : 10.1109/CGO.2007.32
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.76.4471
CHiLL: A framework for composing high-level loop transformations, 2008. ,
Optimizing for reduced code space using genetic algorithms, Workshop on Languages , Compilers, and Tools for Embedded Systems, pp.1-9, 1999. ,
DOI : 10.1145/314403.314414
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.1586
Adaptive optimizing compilers for the 21st century, The Journal of Supercomputing, vol.23, issue.1, pp.7-22, 2002. ,
DOI : 10.1023/A:1015729001611
Fast compiler optimisation evaluation using code-feature based performance prediction, Proceedings of the 4th international conference on Computing frontiers , CF '07, 2007. ,
DOI : 10.1145/1242531.1242553
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.184.8545
Portable compiler optimization across embedded programs and microarchitectures using machine learning, Proceedings of the IEEE/ACM International Symposium on Microarchitecture (MICRO), 2009. ,
Some efficient solutions to the affine scheduling problem. Part II. Multidimensional time, International Journal of Parallel Programming, vol.2, issue.4, pp.389-420, 1992. ,
DOI : 10.1007/BF01379404
Probabilistic sourcelevel optimisation of embedded programs, Proceedings of the 2005 ACM SIGPLAN/SIGBED Conference on Languages, Compilers, and Tools for Embedded Systems, pp.78-86, 2005. ,
The Design and Implementation of FFTW3, special issue on " Program Generation, Optimization, and Platform Adaptation, pp.216-231, 2005. ,
DOI : 10.1109/JPROC.2004.840301
MILEPOST GCC: machine learning based research compiler, Proceedings of the GCC Developers' Summit, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00294704
Semi-Automatic Composition of Loop Transformations for Deep Parallelism and Memory Hierarchies, International Journal of Parallel Programming, vol.20, issue.1, pp.261-317, 2006. ,
DOI : 10.1007/s10766-006-0012-3
URL : https://hal.archives-ouvertes.fr/hal-01257288
Automatic selection of compiler options using non-parametric inferential statistics, 14th International Conference on Parallel Architectures and Compilation Techniques (PACT'05), pp.123-132, 2005. ,
DOI : 10.1109/PACT.2005.9
Supernode partitioning, Proceedings of the 15th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '88, pp.319-329, 1988. ,
DOI : 10.1145/73560.73588
Combined selection of tile sizes and unroll factors using iterative compilation, Proceedings 2000 International Conference on Parallel Architectures and Compilation Techniques (Cat. No.PR00622), p.237, 2000. ,
DOI : 10.1109/PACT.2000.888348
Fast searches for effective optimization phase sequences, Proceedings of the ACM SIGPLAN '04 Conference on Programming Language Design and Implementation, pp.171-182, 2004. ,
Maximizing parallelism and minimizing synchronization with affine transforms, Proceedings of the 24th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '97, pp.201-214, 1997. ,
DOI : 10.1145/263699.263719
A heuristic search algorithm based on unified transformation framework, Proc. of the 2005 Intl. Conf. on Parallel Processing Workshops (ICPPW'05), pp.137-144, 2005. ,
A Machine Learning Approach to Automatic Production of Compiler Heuristics, AIMSA '02: Proc. of the 10th Intl. Conf. on Artificial Intelligence: Methodology, Systems, and Applications, pp.41-50, 2002. ,
DOI : 10.1007/3-540-46148-5_5
Papi ? the performance application programming interface, 2000. ,
Practical aggregation of semantical program properties for machine learning based optimization, Proceedings of the 2010 international conference on Compilers, architectures and synthesis for embedded systems, CASES '10, 2010. ,
DOI : 10.1145/1878921.1878951
URL : https://hal.archives-ouvertes.fr/inria-00551512
Towards a Systematic, Pragmatic and Architecture-Aware Program Optimization Process for Complex Processors, Proceedings of the ACM/IEEE SC2004 Conference, p.15, 2004. ,
DOI : 10.1109/SC.2004.61
URL : https://hal.archives-ouvertes.fr/hal-01257302
Iterative optimization in the polyhedral model: Part II, multidimensional time, ACM SIGPLAN Conf. on Programming Language Design and Implementation (PLDI'08), pp.90-100, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01257273
Iterative Optimization in the Polyhedral Model: Part I, One-Dimensional Time, International Symposium on Code Generation and Optimization (CGO'07) ,
DOI : 10.1109/CGO.2007.21
URL : https://hal.archives-ouvertes.fr/hal-01257281
Combined Iterative and Model-driven Optimization in an Automatic Parallelization Framework, 2010 ACM/IEEE International Conference for High Performance Computing, Networking, Storage and Analysis, 2010. ,
DOI : 10.1109/SC.2010.14
URL : https://hal.archives-ouvertes.fr/inria-00551067
Spiral: Code generation for dsp transforms, special issue on " Program Generation, Optimization, and Platform Adaptation, pp.232-275, 2005. ,
Tiling multidimensional iteration spaces for multicomputers, Journal of Parallel and Distributed Computing, vol.16, issue.2, pp.108-230, 1992. ,
DOI : 10.1016/0743-7315(92)90027-K
A scalable auto-tuning framework for compiler optimization, 2009 IEEE International Symposium on Parallel & Distributed Processing, pp.1-12, 2009. ,
DOI : 10.1109/IPDPS.2009.5161054
Polyhedralmodel guided loop-nest auto-vectorization, Intl. Conf. on Parallel Architectures and Compilation Techniques (PACT'09), 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00645325
Computer Generation of General Size Linear Transform Libraries, 2009 International Symposium on Code Generation and Optimization, pp.102-113, 2009. ,
DOI : 10.1109/CGO.2009.33
Statistical Models for Empirical Search-Based Performance Tuning, International Journal of High Performance Computing Applications, vol.18, issue.1, pp.65-94, 2004. ,
DOI : 10.1177/1094342004041293
Automatically Tuned Linear Algebra Software, Proceedings of the IEEE/ACM SC98 Conference, pp.1-27, 1998. ,
DOI : 10.1109/SC.1998.10004
Automated empirical optimizations of software and the atlas project, Parallel Computing, 2000. ,
More iteration space tiling, Proceedings of the 1989 ACM/IEEE conference on Supercomputing , Supercomputing '89, pp.655-664, 1989. ,
DOI : 10.1145/76263.76337
A comparison of empirical and model-driven optimization, ACM SIGPLAN Conf. on Programming Language Design and Implementation (PLDI'03), 2003. ,
