A Stabilized Finite Element Method for Compressible Turbulent Flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we use a stabilized finite element method to solve Spalart-Allmaras turbulent model for compressible flows. This method is the Streamline-Upwind Petrov-Galerkin one, which enable to put numerical viscosity only along the streamlines. The aim is to build a high order scheme in order not to pollute turbulent eddy viscosity with the diffusivity of the numerical scheme.
Fichier non déposé
inria-00551090 , version 1 (02-01-2011)
  • HAL Id : inria-00551090 , version 1
Christelle Wervaecke, Héloïse Beaugendre, Boniface Nkonga. A Stabilized Finite Element Method for Compressible Turbulent Flows. The Fifth European Conference on Computational Fluid Dynamics ECCOMAS CFD 2010, Jun 2010, Lisbon, Portugal. ⟨inria-00551090⟩
75 Consultations
0 Téléchargements
