Oriented trees in digraphs. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Let f (k) be the smallest integer such that every f (k)-chromatic digraph contains every oriented tree of order k. Burr proved that f (k) ≤ (k − 1)^2 and conjectured f (k) = 2n − 2. In this paper, we give some sufficient conditions for an n-chromatic digraphs to contains some oriented tree. In particular, we show that every acyclic n-chromatic digraph contains every oriented tree of order n. We also show that f (k) ≤ k^2/2 − k/2 + 1. Finally, we consider the existence of antidirected trees in digraphs. We prove that every antidirected tree of order k is containedinevery(5k−9)-chromaticdigraph. Weconjecturethatif|E(D)|>(k−2)|V(D)|,thenthedigraph D contains every antidirected tree of order k. This generalizes Burr's conjecture for antidirected trees and the celebrated Erdo ̋s-So ́s Conjecture. We give some evidences for our conjecture to be true.
RR-7502.pdf (184.16 Ko) Télécharger le fichier
inria-00551133 , version 1 (02-01-2011)
  • HAL Id : inria-00551133 , version 1
Louigi Addario-Berry, Frédéric Havet, Claudia Linhares Sales, Bruce Reed, Stéphan Thomassé. Oriented trees in digraphs.. [Research Report] RR-7502, INRIA. 2011. ⟨inria-00551133⟩
367 Consultations
448 Téléchargements
