Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., pp.7-16, 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
Automatic data movement and computation mapping for multi-level parall el architectures with explicitly managed memories, PPoPP '08: Proc. of the 13th ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, pp.1-10, 2008. ,
A compiler framework for optimization of affine loop nests for gpgpus, ICS '08: Proceedings of the 22nd annual international conference on Supercomputing, pp.225-234, 2008. ,
A practical automatic polyhedral parallelization and locality optimization system, ACM SIG- PLAN Conf. on Programming Languages Design and Implementation (PLDI'08), 2008. ,
The Polyhedral Model Is More Widely Applicable Than You Think, Proceedings of the International Conference on Compiler Construction (ETAPS CC'10), number 6011 in Lecture Notes in Computer Science, 2010. ,
DOI : 10.1007/978-3-642-11970-5_16
URL : https://hal.archives-ouvertes.fr/inria-00551087
Automatic c-to-cuda code generation for affine programs, Proceedings of the International Conference on Compiler Construction (CC 2010), number 6011 in Lecture Notes in Computer Science, pp.244-263, 2010. ,
Automatic Parallelization of Loop Programs for Distributed Memory Architectures, 2004. ,
Precise Management of Scratchpad Memories for Localising Array Accesses in Scientific Codes, Proceedings of the International Conference on Compiler Construction number 5501 in Lecture Notes in Computer Science, pp.236-250, 2009. ,
DOI : 10.1007/978-3-642-00722-4_17
The Organization of Computations for Uniform Recurrence Equations, Journal of the ACM, vol.14, issue.3, pp.563-590, 1967. ,
DOI : 10.1145/321406.321418
The parallel execution of DO loops, CONCUR'93, pp.83-93, 1974. ,
DOI : 10.1145/360827.360844
Iterative optimization in the polyhedral model: Part II, multidimensional time, ACM Conf. on Programming Language Design and Implementation (PLDI'08), 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01257273
