A Stream-Comptuting Extension to OpenMP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces an extension to OpenMP 3.0 enabling stream programming with minimal, incremental additions that seamlessly integrate into the current specification. The stream programming model decomposes programs into tasks and explicits the flow of data among them, thus exposing data, task and pipeline parallelism. It helps the programmers to express concurrency and data locality properties, avoiding non-portable low-level code and early optimizations. We survey the diverse motivations and constraints converging towards the design of our simple yet powerful language extension, and we present experimental results of a prototype implementation in a public branch of GCC 4.5.
poster_abs.pdf (105.21 Ko) Télécharger le fichier
Pop_slides.pdf (2.15 Mo) Télécharger le fichier
Format : Autre
inria-00551519 , version 1 (04-01-2011)
  • HAL Id : inria-00551519 , version 1
Antoniu Pop, Albert Cohen. A Stream-Comptuting Extension to OpenMP. International Workshop on OpenMP (IWOMP'10), Jun 2010, Tsukuba, Japan. ⟨inria-00551519⟩
242 Consultations
194 Téléchargements
