Erbium: A Deterministic, Concurrent Intermediate Representation for Portable and Scalable Performance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Optimizing compilers and runtime libraries do not shield programmers from the complexity of multi-core hardware; as a result the need for manual, target-specific optimizations increases with every processor generation. High-level languages are being designed to express concurrency and locality without reference to a particular architecture. But compiling such abstractions into efficient code requires a portable, intermediate representation: this is essential for modular composition (separate compilation), for optimization frameworks independent of the source language, and for just-in-time compilation of bytecode languages. This paper introduces Erbium, an intermediate representation for compilers, a low-level language for efficiency programmers, and a lightweight runtime implementation. It relies on a data structure for scalable and deterministic concurrency, called Event Record, exposing the data-level, task and pipeline parallelism suitable to a given target. We provide experimental evidence of the productivity, scalability and efficiency advantages of Erbium, relying on a prototype implementation in GCC 4.3.
cf154-miranda.pdf (94.43 Ko) Télécharger le fichier
poster_final.pdf (1.21 Mo) Télécharger le fichier
Format : Autre
inria-00551520 , version 1 (04-01-2011)
  • HAL Id : inria-00551520 , version 1
Cupertino Miranda, Philippe Dumont, Albert Cohen, Marc Duranton, Antoniu Pop. Erbium: A Deterministic, Concurrent Intermediate Representation for Portable and Scalable Performance. ACM International Conference on Computing Frontiers (CF'10), May 2010, Bertinoro, Italy. ⟨inria-00551520⟩
205 Consultations
163 Téléchargements
