Oscillation criteria in delay equations, Journal of Differential Equations, vol.53, issue.1, pp.115-123, 1984. ,
DOI : 10.1016/0022-0396(84)90028-7
Existence of periodic solutions for delaydifferential equations with state-depending delay, J.Diff.Equat, vol.1442, pp.263-301, 1998. ,
Oscillations in vector spaces: A comparison result for monotone delay differential systems, Journal of Mathematical Analysis and Applications, vol.160, issue.1, pp.267-283, 1991. ,
DOI : 10.1016/0022-247X(91)90305-J
Subdominant behavior in positive semigroups. The case of a class of delay differential equations, Differ. Equ. Dyn. Syst, vol.4, issue.1, pp.99-111, 1996. ,
Existence of oscillating solutions for certain differential equations with delay, Proc. Lect. Notes Math, vol.17, issue.51, pp.46-64, 1978. ,
DOI : 10.1007/BF02417109
Global Results for an Epidemic Model with Vaccination that Exhibits Backward Bifurcation, SIAM Journal on Applied Mathematics, vol.64, issue.1, pp.260-276, 2003. ,
DOI : 10.1137/S0036139902413829
The mathematical Theory of Infectious diseases, 1975. ,
The oscillation and exponential decay rate of solutions of differential delay equations, Proc. Spec. Sess. AMS Contemp. Math, vol.129, pp.43-54, 1991. ,
DOI : 10.1090/conm/129/1174133
Mathematical epidemiology of infectious diseases: Model Building Analysis and Interpretation, Wiley series in Mathematical and computational Biology, 2000. ,
Connections between compartmental systems with pipes and integro-differential equations, Mathematical Modelling, vol.7, issue.9-12, pp.1215-1238, 1986. ,
DOI : 10.1016/0270-0255(86)90077-1
Oscillation theory of delay differential equations. Oxford Mathematical Monographs, 1991. ,
Introduction to Functional Differential Equations, 1991. ,
DOI : 10.1007/978-1-4612-4342-7
PERIODICITY AND STABILITY IN EPIDEMIC MODELS: A SURVEY, differential Equations and Applications in Ecology, Epidemic and Population Problems, 1981. ,
DOI : 10.1016/B978-0-12-148360-9.50011-1
Systems of Differential Equations that are Competitive or Cooperative II: Convergence Almost Everywhere, SIAM Journal on Mathematical Analysis, vol.16, issue.3, pp.423-439, 1965. ,
DOI : 10.1137/0516030
When all solutions of x (t) = ? n i=1 x(t ? T i (t)) oscillate, J.Differential Equations, vol.53, pp.138-145, 1984. ,
Necessary and Sufficient Conditions for Oscillations, The American Mathematical Monthly, vol.90, issue.9, p.637, 1983. ,
DOI : 10.2307/2323283
Oscillations caused by several retarded and advanced arguments, Journal of Differential Equations, vol.44, issue.1, pp.134-152, 1982. ,
DOI : 10.1016/0022-0396(82)90029-8
Morse Decompositions for delay-differential equations, Journal of Differential Equations, vol.72, issue.2, pp.270-315, 1988. ,
DOI : 10.1016/0022-0396(88)90157-X
Oscillations in Differential Equations with State-Dependent Delays, Nonlinear Oscillations, vol.6, issue.2, pp.250-257, 2003. ,
DOI : 10.1023/B:NONO.0000007825.34718.61
Etudes des propriétés oscillatoires de systèmes diffèrentielsdiffèrentielsà retard de type monotone , thèse de 3` eme Cycle de l, 1988. ,
Monotone semiflows generated by functional differential equations, Journal of Differential Equations, vol.66, issue.3, pp.420-442, 1987. ,
DOI : 10.1016/0022-0396(87)90027-1
URL : http://doi.org/10.1016/0022-0396(87)90027-1
Monotone dynamical systems: An Introduction to the Theory of competitive and cooperative Systems, Mathematical Surveys and Monographs, vol.41, 1995. ,
DOI : 10.1090/surv/041
Epidemic and demographic interaction in the spread of potentially fatal disease in governing populations, Math.Biosci, issue.111, pp.99-130, 1992. ,
