PASSAGE: from French Parser Evaluation to Large Sized Treebank - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper we present the PASSAGE project which aims at building automatically a French Treebank of large size by combining the output of several parsers, using the EASY annotation scheme. We present also the results of the of the first evaluation campaign of the project and the preliminary results we have obtained with our ROVER procedure for combining parsers automatically.
Fichier non déposé
inria-00553522 , version 1 (07-01-2011)
  • HAL Id : inria-00553522 , version 1
Éric Villemonte de La Clergerie, Olivier Hamon, Djamel Mostefa, Christelle Ayache, Patrick Paroubek, et al.. PASSAGE: from French Parser Evaluation to Large Sized Treebank. Proceedings of the Sixth International Language Resources and Evaluation (LREC'08), 2008, Marrakech, Morocco. ⟨inria-00553522⟩
88 Consultations
0 Téléchargements
