Source coding theory, 1990. ,
DOI : 10.1007/978-1-4613-1643-5
Asymptotic quantization error of continuous signals and the quantization dimension, IEEE Transactions on Information Theory, vol.28, issue.2, pp.139-148, 1982. ,
DOI : 10.1109/TIT.1982.1056490
Lagrangian Vector Quantization With Combined Entropy and Codebook Size Constraints, IEEE Transactions on Information Theory, vol.54, issue.5, pp.2209-2242, 2008. ,
DOI : 10.1109/TIT.2008.920205
A posteriori quantization of progressive matching pursuit streams, IEEE Transactions on Signal Processing, vol.52, issue.2, pp.525-535, 2004. ,
DOI : 10.1109/TSP.2003.821105
Embedded Polar Quantization, IEEE Signal Processing Letters, vol.14, issue.10, pp.657-660, 2007. ,
DOI : 10.1109/LSP.2007.896379
URL : https://hal.archives-ouvertes.fr/hal-00161462
PDF optimized parametric vector quantization of speech line spectral frequencies, IEEE Transactions on Speech and Audio Processing, vol.11, issue.2, pp.130-142, 2003. ,
DOI : 10.1109/TSA.2003.809192
On entropy-constrained vector quantization using gaussian mixture models, IEEE Transactions on Communications, vol.56, issue.12, pp.2094-2104, 2008. ,
DOI : 10.1109/TCOMM.2008.070357
Waveform quantization of speech using Gaussian mixture models, 2004 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.165-168, 2004. ,
DOI : 10.1109/ICASSP.2004.1325948
A low-delay audio coder with constrainedentropy quantization, IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA'07), pp.191-194, 2007. ,
Flexible Quantization of Audio and Speech based on the Autoregressive Model, 2007 Conference Record of the Forty-First Asilomar Conference on Signals, Systems and Computers, pp.535-539, 2007. ,
DOI : 10.1109/ACSSC.2007.4487270
A High-Rate Optimal Transform Coder With Gaussian Mixture Companders, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.3, pp.770-783, 2007. ,
DOI : 10.1109/TASL.2006.885905
Optimal parameter estimation for modelbased quantization, IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.2497-2500, 2009. ,
Rate Distribution Between Model and Signal, 2007 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, pp.243-246, 2007. ,
DOI : 10.1109/ASPAA.2007.4393033
Model Selection Based on Minimum Description Length, Journal of Mathematical Psychology, vol.44, issue.1, pp.133-152, 2000. ,
DOI : 10.1006/jmps.1999.1280
Results and conjectures on high rate quantization, Data Compression Conference, 2004. Proceedings. DCC 2004, pp.3-12, 2004. ,
DOI : 10.1109/DCC.2004.1281445
Two results on the asymptotic performance of quantizers, IEEE Transactions on Information Theory, vol.30, issue.2, pp.341-348, 1984. ,
DOI : 10.1109/TIT.1984.1056877
Mismatch in high-rate entropy-constrained vector quantization, IEEE Transactions on Information Theory, vol.49, issue.5, pp.1204-1217, 2003. ,
DOI : 10.1109/TIT.2003.810637
Modeling by shortest data description, Automatica, vol.14, issue.5, pp.465-471, 1978. ,
DOI : 10.1016/0005-1098(78)90005-5
Minimum complexity density estimation, IEEE Transactions on Information Theory, vol.37, issue.4, pp.1034-1054, 1991. ,
DOI : 10.1109/18.86996
Vector Quantization and Signal Compression, 1992. ,
DOI : 10.1007/978-1-4615-3626-0
Asymptotically optimal block quantization, IEEE Transactions on Information Theory, vol.25, issue.4, pp.373-380, 1979. ,
DOI : 10.1109/TIT.1979.1056067
Low-Complexity Source Coding Using Gaussian Mixture Models, Lattice Vector Quantization, and Recursive Coding with Application to Speech Spectrum Quantization, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.2, pp.524-532, 2006. ,
DOI : 10.1109/TSA.2005.855839
High-resolution quantization theory and the vector quantizer advantage, IEEE Transactions on Information Theory, vol.35, issue.5, pp.1020-1033, 1989. ,
DOI : 10.1109/18.42217
High-resolution source coding for non-difference distortion measures: multidimensional companding, IEEE Transactions on Information Theory, vol.45, issue.2, pp.548-561, 1999. ,
DOI : 10.1109/18.749002
Low-complexity wideband LSF quantization by predictive KLT coding and generalized Gaussian modeling, EUSIPCO, 14th European Signal Processing Conference, 2006. ,
Speech enhancement in the DFT domain using Laplacian speech priors, Proc. 8th Intern. Workshop on Acoustic Echo and Noise Control (IWAENC), pp.87-90, 2003. ,
Complex nonconvex lp norm minimization for underdetermined source separation, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA'07), pp.430-437, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00544203
The segmental K-means algorithm for estimating parameters of hidden Markov models, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.38, issue.9, pp.1639-1641, 1990. ,
DOI : 10.1109/29.60082
Maximum likelihood from incomplete data via the EM algorithm, Journal of the Royal Statistical Society. Series B (Methodological), vol.39, pp.1-38, 1977. ,
