Data Category Registry: Morpho-syntactic and Syntactic Profiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
After a brief presentation of the data model, we describe a work in progress to define an initial set of morpho-syntactic and syntactic data categories dedicated to NLP applications. The aim is to improve interoperability among language resources and to optimize the process leading to their integration in applications. The main point is to be sure that when a language resource makes use of a value, the other language resources and programs have the same interpretation for this given value. From a practical point of view, these values are collected from existing lists, discussed, extended, and then recorded within a freely accessible data base: the ISO Data Category Registry.
LREC2008MarrakechStandardsWorkshopDCRProfiles.pdf (116.15 Ko) Télécharger le fichier
inria-00553563 , version 1 (07-01-2011)
  • HAL Id : inria-00553563 , version 1
Gil Francopoulo, Thierry Declerck, Virach Sornlertlamvanich, Éric Villemonte de La Clergerie, Monica Monachini. Data Category Registry: Morpho-syntactic and Syntactic Profiles. LREC-2008 Workshop on Uses and usage of language resource-related standards, 2008, Marrakech, Morocco. ⟨inria-00553563⟩
92 Consultations
131 Téléchargements
