A bi-criteria scheduling heuristic for distributed embedded systems under reliability and real-time constraints, International Conference on Dependable Systems and Networks, 2004 ,
DOI : 10.1109/DSN.2004.1311904
Basic concepts and taxonomy of dependable and secure computing, IEEE Transactions on Dependable and Secure Computing, vol.1, issue.1, pp.11-33, 2004. ,
DOI : 10.1109/TDSC.2004.2
Some effects of redundancy on system reliability, National Symposium on Reliability and Quality Control, pp.385-402, 1960. ,
Fault-tolerant platforms for automotive safetycritical applications, International Conference on Compilers, Architectures and Synthesis for Embedded Systems, CASES'03, 2003. ,
DOI : 10.1145/951710.951734
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.8092
Optimizing latency and reliability of pipeline workflow applications, 2008 IEEE International Symposium on Parallel and Distributed Processing, 2008. ,
DOI : 10.1109/IPDPS.2008.4536160
URL : https://hal.archives-ouvertes.fr/hal-00803486
Mapping pipeline skeletons onto heterogeneous platforms, Journal of Parallel and Distributed Computing, vol.68, issue.6, pp.790-808, 2008. ,
DOI : 10.1016/j.jpdc.2007.11.004
URL : https://hal.archives-ouvertes.fr/hal-00118921
Complexity Results for Throughput and Latency Optimization of Replicated and Data-parallel Workflows, Algorithmica, vol.5, issue.9, pp.689-724, 2010. ,
DOI : 10.1007/s00453-008-9229-4
URL : https://hal.archives-ouvertes.fr/hal-00803515
High-performance software for mathematical programming and optimization ,
Matching and scheduling algorithms for minimizing execution time and failure probability of applications in heterogeneous computing, IEEE Transactions on Parallel and Distributed Systems, vol.13, issue.3, pp.308-323, 2002. ,
DOI : 10.1109/71.993209
Bi-objective scheduling algorithms for optimizing makespan and reliability on heterogeneous systems, Proceedings of the nineteenth annual ACM symposium on Parallel algorithms and architectures , SPAA '07, pp.280-288, 2007. ,
DOI : 10.1145/1248377.1248423
URL : https://hal.archives-ouvertes.fr/hal-00155964
Source Code for the Experiments ,
Reliable and Precise WCET Determination for a Real-Life Processor, Int. Workshop on Embedded Software, EMSOFT'01, 2001. ,
DOI : 10.1007/3-540-45449-7_32
Fundamentals of fault-tolerant distributed computing in asynchronous environments, ACM Computing Surveys, vol.31, issue.1, pp.1-26, 1999. ,
DOI : 10.1145/311531.311532
A Novel Bicriteria Scheduling Heuristics Providing a Guaranteed Global System Failure Rate, IEEE Transactions on Dependable and Secure Computing, vol.6, issue.4, pp.241-254, 2009. ,
DOI : 10.1109/TDSC.2008.50
URL : https://hal.archives-ouvertes.fr/hal-00746768
Reliability versus performance for critical applications, Journal of Parallel and Distributed Computing, vol.69, issue.3, pp.326-336, 2009. ,
DOI : 10.1016/j.jpdc.2008.11.002
URL : https://hal.archives-ouvertes.fr/hal-00753169
A bi-objective algorithm for scheduling parallel applications on heterogeneous systems subject to failures, Rencontres Francophones du Parallélisme, RENPAR'06, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00148583
Adaptive Allocation of Independent Tasks to Maximize Throughput, IEEE Transactions on Parallel and Distributed Systems, vol.18, issue.10, pp.1420-1435, 2007. ,
DOI : 10.1109/TPDS.2007.1042
Bi-objective Approximation Scheme for Makespan and Reliability Optimization on Uniform Parallel Machines, Euro-Par, pp.877-886, 2008. ,
DOI : 10.1007/978-3-540-85451-7_94
URL : https://hal.archives-ouvertes.fr/inria-00333906
An Algorithm to Determine the Reliability of a Complex System, IEEE Transactions on Reliability, vol.18, issue.4, pp.169-174, 1969. ,
DOI : 10.1109/TR.1969.5216346
An experimental evaluation of the assumption of independence in multi-version programming, IEEE Trans. Software Engin, vol.12, issue.1, pp.96-109, 1986. ,
Reliability, 1962. ,
DOI : 10.1201/9781420017656.ch7
Scheduling and voltage scaling for energy/reliability trade-offs in fault-tolerant time-triggered embedded systems, Proceedings of the 5th IEEE/ACM international conference on Hardware/software codesign and system synthesis , CODES+ISSS '07, 2007. ,
DOI : 10.1145/1289816.1289873
Analyzing scheduling with transient failures, Information Processing Letters, vol.109, issue.11, pp.539-542, 2009. ,
DOI : 10.1016/j.ipl.2009.01.019
URL : https://hal.archives-ouvertes.fr/hal-00800413
Models and algorithms for reliability-oriented task-allocation in redundant distributed-computer systems, IEEE Transactions on Reliability, vol.38, issue.1, pp.16-26, 1989. ,
DOI : 10.1109/24.24570
Computing the worst case execution time of an avionics program by abstract interpretation, International Workshop on Worst-case Execution Time, WCET'05, pp.21-24, 2005. ,
Optimal mapping of sequences of data parallel tasks, PPoPP'95, pp.134-143, 1995. ,
Optimal latency-throughput tradeoffs for data parallel pipelines, Proceedings of the eighth annual ACM symposium on Parallel algorithms and architectures , SPAA '96, pp.62-71, 1996. ,
DOI : 10.1145/237502.237508
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.34.6335
The effects of energy management on reliability in real-time embedded systems, International Conference on Computer Aided Design, ICCAD'04, pp.35-40, 0655. ,
