Practical, Pluggable Types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Most languages fall into one of two camps: either they adopt a unique, static type system, or they abandon static type-checks for run-time checks. Pluggable types blur this division by (i) making static type systems optional, and (ii) supporting a choice of type systems for reasoning about different kinds of static properties. Dynamic languages can then benefit from static-checking without sacrificing dynamic features or committing to a unique, static type system. But the overhead of adopting pluggable types can be very high, especially if all existing code must be decorated with type annotations before any type-checking can be performed. We propose a practical and pragmatic approach to introduce pluggable type systems to dynamic languages. First of all, only annotated code is type-checked. Second, limited type inference is performed on unannotated code to reduce the number of reported errors. Finally, external annotations can be used to type third-party code. We present Typeplug, a Smalltalk implementation of our framework, and report on experience applying the framework to three different pluggable type systems.
Hald07b-Typeplug.pdf (177.06 Ko) Télécharger le fichier
inria-00555783 , version 1 (14-01-2011)
Niklaus Haldiman, Marcus Denker, Oscar Nierstrasz. Practical, Pluggable Types. 2007 International Conference on Dynamic Languages (ICDL 2007), ESUG, 2007, Lugano, Switzerland. pp.183-204, ⟨10.1145/1352678.1352690⟩. ⟨inria-00555783⟩
35 Consultations
102 Téléchargements
