INRIA LEAR-TEXMEX: Video copy detection task - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hervé Jégou
  • Fonction : Auteur
  • PersonId : 833473
Matthijs Douze
  • Fonction : Auteur
  • PersonId : 843109
Guillaume Gravier
Cordelia Schmid
  • Fonction : Auteur
  • PersonId : 831154
Patrick Gros
In this paper we present the results of our experiments in the Trecvid'10 copy detection task and introduce the components of our system. In particular, we describe the recent approximate nearest neighbor search method we used to index the hundreds millions of audio descriptors. Our system obtained excellent accuracy and localization results, achieving the best performance on a few transformations, and this with a single kind of image descriptor. Moreover, the analysis evidences that our system can be significantly improved.
paper.pdf (318.67 Ko) Télécharger le fichier
Format : Figure, Image
inria-00555825 , version 1 (09-02-2011)
  • HAL Id : inria-00555825 , version 1
Hervé Jégou, Matthijs Douze, Guillaume Gravier, Cordelia Schmid, Patrick Gros. INRIA LEAR-TEXMEX: Video copy detection task. TRECVid 2010 Workshop, Nov 2010, Gaithersburg, United States. ⟨inria-00555825⟩
856 Consultations
207 Téléchargements
