Generalizing AGM to a multi-agent setting
We generalize AGM belief revision theory to the multi-agent case. To do so, we first generalize the semantics of the single-agent case, based on the notion of interpretation, to the multi-agent case. Then we show that, thanks to the shape of our new semantics, all the results of the AGM framework transfer. Afterwards we investigate some postulates that are specific to our multi-agent setting. Finally, we give an example of revision operator that fulfills one of these new postulates and give an example of revision on a concrete example.
