How our beliefs contribute to interpret actions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
In update logic the interpretation of an action is often assumed to be independent from the agents' beliefs about the situation (see [BMS04] or [Auc05]). In this paper we deal with this type of phe- nomenon. We also deal with actions that change facts of the situation. We use probability to model the notion of belief and our probabilistic update mechanism satisfies the AGM postulates of belief revision.
10.1007-11559221_28.pdf (209.65 Ko) Télécharger le fichier
inria-00556095 , version 1 (15-01-2011)
inria-00556095 , version 2 (08-09-2013)
  • HAL Id : inria-00556095 , version 2
Guillaume Aucher. How our beliefs contribute to interpret actions. CEEMAS - Central and Eastern European Conference on Multi-Agent Systems - 2005, Sep 2005, Budapest, Hungary. ⟨inria-00556095v2⟩
117 Consultations
370 Téléchargements
