Practical Cryptanalysis of the Identification Scheme Based on the Isomorphism of Polynomial With One Secret Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a practical cryptanalysis of the Identification Scheme proposed by Patarin at Crypto 1996. This scheme relies on the hardness of the Isomorphism of Polynomial with One Secret (IP1S), and enjoys shorter key than many other schemes based on the hardness of a combinatorial problem (as opposed to number-theoretic problems). Patarin proposed concrete parameters that have not been broken faster than exhaustive search so far. On the theoretical side, IP1S has been shown to be harder than Graph Isomorphism, which makes it an interesting target. We present two new deterministic algorithms to attack the IP1S problem, and we rigorously analyze their complexity and success probability. We show that they can solve a (big) constant fraction of all the instances of degree two in polynomial time. We verified that our algorithms are very efficient in practice. All the parameters with degree two proposed by Patarin are now broken in a few seconds. The parameters with degree three can be broken in less than a CPU-month. The identification scheme is thus quite badly broken.
pkc11.pdf (244.73 Ko) Télécharger le fichier
inria-00556671 , version 1 (17-01-2011)
Charles Bouillaguet, Jean-Charles Faugère, Pierre-Alain Fouque, Ludovic Perret. Practical Cryptanalysis of the Identification Scheme Based on the Isomorphism of Polynomial With One Secret Problem. 14th IACR International Conference on Practice and Theory of Public Key Cryptography - PKC 2011, Mar 2011, Taormina, Italy. pp.473-493, ⟨10.1007/978-3-642-19379-8_29⟩. ⟨inria-00556671⟩
435 Consultations
256 Téléchargements
