New interface
Conference papers
Practical Electromagnetic Template Attack on HMAC
Abstract : In this paper, we show that HMAC can be attacked using a very efficient side channel attack which reveals the Hamming distance of some registers. After a profiling phase which requires access to a similar device that can be configured by the adversary, the attack recovers the secret key on one recorded execution of HMAC-SHA-1 for example, on an embedded device. We perform experimentations using a NIOS processor executed on a Field Programmable Gate Array (FPGA) to confirm the leakage model. Besides the high efficiency of this attack, $2^32\cdot 3^k$ where $k$ is the number of 32-bit words of the key, that we tested with experimentations, our results also shed some light on the on the requirements in term of side channel attack for the future SHA-3 function. Finally, we show that our attack can also be used to break the confidentiality of network protocols usually implemented on embedded devices. We have performed experiments using a NIOS processor executed on a Field Programmable Gate Array (FPGA) to confirm the leakage model. We hope that our results shed some light on the requirements in term of side channel attack for the future SHA-3 function.
Document type :
Conference papers
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/inria-00556681
Contributor : Pierre-Alain Fouque Connect in order to contact the contributor
Submitted on : Monday, January 17, 2011 - 3:37:13 PM
Last modification on : Thursday, March 17, 2022 - 10:08:36 AM
Long-term archiving on: : Monday, April 18, 2011 - 3:00:13 AM
File
ches09.pdf
Identifiers
Collections
Citation
Pierre-Alain Fouque, Gaëtan Leurent, Denis Réal, Frédéric Valette. Practical Electromagnetic Template Attack on HMAC. Cryptographic Hardware and Embedded Systems - CHES 2009, 11th International Workshop, 2009, Lausanne, Switzerland. pp.66-80, ⟨10.1007/978-3-642-04138-9_6⟩. ⟨inria-00556681⟩
Share
Metrics
Record views
111
Files downloads
265
