A program data flow analysis procedure, Communications of the ACM, vol.19, issue.3, p.137, 1976. ,
DOI : 10.1145/360018.360025
Modern Compiler Implementation in Java, 2002. ,
The LCA Problem Revisited, LATIN 2000: Theoretical Informatics, pp.88-94, 2000. ,
DOI : 10.1007/10719839_9
Revisiting Out-of-SSA Translation for Correctness, Code Quality and Efficiency, 2009 International Symposium on Code Generation and Optimization, pp.114-125, 2009. ,
DOI : 10.1109/CGO.2009.19
URL : https://hal.archives-ouvertes.fr/inria-00349925
Register allocation: What does the NP-completeness proof of Chaitin et al. really prove?, International Workshop on Languages and Compilers for Parallel Computing, pp.283-298, 2006. ,
Practical improvements to the construction and destruction of static single assignment form, Software: Practice and Experience, vol.28, issue.8, pp.859-881, 1998. ,
DOI : 10.1002/(SICI)1097-024X(19980710)28:8<859::AID-SPE188>3.0.CO;2-8
An efficient representation for sparse sets, ACM Letters on Programming Languages and Systems, vol.2, issue.1-4, pp.59-69, 1993. ,
DOI : 10.1145/176454.176484
Folklore confirmed: Reducible flow graphs are exponentially larger, ACM SIGACT/SIGPLAN Symposium on Principles of Programming Languages (POPL'03), pp.106-114, 2003. ,
A simple graph-based intermediate representation, ACM SIGPLAN Workshop on Intermediate Representations, pp.35-49, 1995. ,
An Empirical Study of Iterative Data-Flow Analysis, 2006 15th International Conference on Computing, pp.266-276, 2006. ,
DOI : 10.1109/CIC.2006.22
Efficiently computing static single assignment form and the control dependence graph, ACM Transactions on Programming Languages and Systems, vol.13, issue.4, pp.451-490, 1991. ,
DOI : 10.1145/115372.115320
Code generator optimizations for the ST120 DSP-MCU core, Proceedings of the international conference on Compilers, architectures, and synthesis for embedded systems , CASES '00, pp.93-102, 2000. ,
DOI : 10.1145/354880.354894
Register Allocation for Programs in SSA-Form, International Conference on Compiler Construction, pp.247-262, 2006. ,
DOI : 10.1007/11688839_20
Nesting of reducible and irreducible loops, ACM Transactions on Programming Languages and Systems, vol.19, issue.4, pp.557-567, 1997. ,
DOI : 10.1145/262004.262005
Characterizations of Reducible Flow Graphs, Journal of the ACM, vol.21, issue.3, pp.367-375, 1974. ,
DOI : 10.1145/321832.321835
Analysis of a simple algorithm for global data flow problems, 1st annual ACM SIGACT-SIGPLAN Symposium on Principles of Programming Languages (POPL'73), pp.207-217, 1973. ,
Making graphs reducible with controlled node splitting, ACM Transactions on Programming Languages and Systems, vol.19, issue.6, pp.1031-1052, 1997. ,
DOI : 10.1145/267959.269971
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.46.3925
Global data flow analysis and iterative algorithms, Journal of the ACM, vol.23, issue.1, pp.158-171, 1976. ,
A unified approach to global program optimization, 1st annual ACM SIGACT-SIGPLAN Symposium on Principles of Programming Languages (POPL'73), pp.194-206, 1973. ,
Design of the Java HotSpot#8482; client compiler for Java 6, ACM Transactions on Architecture and Code Optimization, vol.5, issue.1, pp.1-32, 2008. ,
DOI : 10.1145/1369396.1370017
Static single assignment form for machine code, ACM SIGPLAN Conference on Programming Language Design and Implementation (PLDI'99), pp.204-214, 1999. ,
DOI : 10.1145/301631.301667
A library that provides an intermediate representation and optimisations for compilers ,
On the complexity analysis of static analyses, Journal of the ACM, vol.49, issue.4, pp.512-537, 2002. ,
DOI : 10.1145/581771.581774
LTUR: a simplified linear-time unit resolution algorithm for horn formulae and computer implementation, Information Processing Letters, vol.29, issue.1, pp.1-12, 1988. ,
DOI : 10.1016/0020-0190(88)90124-X
Principles of Program Analysis, 1999. ,
DOI : 10.1007/978-3-662-03811-6
Register Allocation Via Coloring of Chordal Graphs, Proceedings of Asian Symposium on Programming Languages and Systems (APLAS'05), pp.315-329, 2005. ,
DOI : 10.1007/11575467_21
Identifying loops in almost linear time, ACM Transactions on Programming Languages and Systems, vol.21, issue.2, pp.175-188, 1999. ,
DOI : 10.1145/316686.316687
On loops, dominators, and dominance frontiers, ACM Transactions on Programming Languages and Systems, vol.24, issue.5, pp.455-490, 2002. ,
DOI : 10.1145/570886.570887
Elimination algorithms for data flow analysis, ACM Computing Surveys, vol.18, issue.3, pp.277-316, 1986. ,
Translating Out of Static Single Assignment Form, Proceedings of the 6th International Symposium on Static Analysis (SAS'99), pp.194-210, 1999. ,
DOI : 10.1007/3-540-48294-6_13
Testing flow graph reducibility, Journal of Computer and System Sciences, vol.9, issue.3, pp.355-365, 1974. ,
DOI : 10.1016/S0022-0000(74)80049-8
URL : http://doi.org/10.1016/s0022-0000(74)80049-8
