On various multifractal spectra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2004
We introduce two classes of multifractal spectra, called respectively dimension and continuous spectra. Dimension spectra offer an interesting alternative to the classical Hausdorff spectrum: They are much easier to estimate yet still give relevant information about the geometry of the H¨older function. Continuous spectra are a generalization of the large deviation spectrum that allow to obtain partition free results. Both classes of spectra allow to perform efficient multifractal analysis in an experimental framework
jlvctfinal.pdf (164.01 Ko) Télécharger le fichier
inria-00559102 , version 1 (14-03-2011)
Jacques Lévy Véhel, Claude Tricot. On various multifractal spectra. Christoph Bandt; Umberto Mosco; Martina Zähle. Fractal Geometry and Stochastics III, 57, Springer, pp.23-42, 2004, Progress in Probability, ⟨10.1007/978-3-0348-7891-3_2⟩. ⟨inria-00559102⟩
78 Consultations
164 Téléchargements
