New interface
Reports (Technical report)
A note on the generation of allophonic rules
Abstract : Algorithms modeling the acquisition of allophonic rules by infants need a 'standard' allophonic grammar against which to evaluate their results. Because no wide-covering grammar exist in the literature and, most importantly, because allophonic complexity is a parameter that needs to be controlled, a common workaround has been to apply grammars of artificial allophonic rules to phonemically-transcribed corpora. We present a new algorithm to generate such allophonic rules, enforcing their linguistic plausibility using a description of phonemes in terms of distinctive features. Controlling the size of the allophonic grammar, we are able to generate transcriptions of various phonetic granularities.
Document type :
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/inria-00559270
Contributor : Luc Boruta Connect in order to contact the contributor
Submitted on : Tuesday, August 28, 2012 - 4:55:18 PM
Last modification on : Wednesday, November 2, 2022 - 11:29:29 AM
Long-term archiving on: : Thursday, November 29, 2012 - 3:37:09 AM
Identifiers
  • HAL Id : inria-00559270, version 2
Citation
Luc Boruta. A note on the generation of allophonic rules. [Technical Report] RT-0401, INRIA. 2011. ⟨inria-00559270v2⟩
Share
Metrics
Record views
130
Files downloads
274
