Using non-convex approximations for efficient analysis of timed automata: Extended version - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The reachability problem for timed automata asks if there exists a path from an initial state to a target state. The standard solution to this problem involves computing the zone graph of the automaton, which in principle could be infinite. In order to make the graph finite, zones are approximated using an extrapolation operator. For reasons of efficiency in current algorithms extrapolation of a zone is always a zone; and in particular it is convex. In this paper, we propose to solve the reachability problem without such extrapolation operators. To ensure termination, we provide an efficient algorithm to check if a zone is included in the so called region closure of another. Although theoretically better, closure cannot be used in the standard algorithm since a closure of a zone may not be convex. An additional benefit of the proposed approach is that it permits to calculate approximating parameters on-the-fly during exploration of the zone graph, as opposed to the current methods which do it by a static analysis of the automaton prior to the exploration. This allows for further improvements in the algorithm. Promising experimental results are presented.
m-HAL.pdf (528.52 Ko) Télécharger le fichier
inria-00559902 , version 1 (26-01-2011)
inria-00559902 , version 2 (10-07-2011)
inria-00559902 , version 3 (03-11-2011)
Frédéric Herbreteau, D. Kini, B. Srivathsan, Igor Walukiewicz. Using non-convex approximations for efficient analysis of timed automata: Extended version. IARCS Annual Conference on Foundations of Software Technology and Theoretical Computer Science, FSTTCS 2011, December 12-14, 2011, Mumbai, India, IIT Bombay, Dec 2011, Mumbai, India. pp.78-89, ⟨10.4230/LIPIcs.FSTTCS.2011.78⟩. ⟨inria-00559902v3⟩
Collections
CNRS
447 Consultations
302 Téléchargements
