A low-memory algorithm for finding short product representations in finite groups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Designs, Codes and Cryptography Année : 2011
We describe a space-efficient algorithm for solving a generalization of the subset sum problem in a finite group G, using a Pollard-rho approach. Given an element z and a sequence of elements S, our algorithm attempts to find a subsequence of S whose product in G is equal to z. For a random sequence S of length d log_2 n, where n=#G and d >= 2 is a constant, we find that its expected running time is O(sqrt(n) log n) group operations (we give a rigorous proof for d > 4), and it only needs to store O(1) group elements. We consider applications to class groups of imaginary quadratic fields, and to finding isogenies between elliptic curves over a finite field.
inria-00560256 , version 1 (27-01-2011)
Gaetan Bisson, Andrew V. Sutherland. A low-memory algorithm for finding short product representations in finite groups. Designs, Codes and Cryptography, 2011, ⟨10.1007/s10623-011-9527-8⟩. ⟨inria-00560256⟩
153 Consultations
0 Téléchargements
