Catalog Based Representation of 2D triangulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computational Geometry and Applications Année : 2011
Several Representations and Coding schemes have been proposed to represent efficiently 2D triangulations. In this paper we propose a new practical approach to reduce the main memory space needed to represent an arbitrary triangulation, while maintaining constant time for some basic queries. This work focuses on the connectivity information of the triangulation, rather than the geometric information (vertex coordinates), since the combinatorial data represents the main part of the storage. The main idea is to gather triangles into patches, to reduce the number of pointers by eliminating the internal pointers in the patches and reducing the multiple references to vertices. To accomplish this, we define and use stable catalogs of patches that are closed under basic standard update operations such as insertion and deletion of vertices, and edge flips. We present some bounds and results concerning special catalogs, and some experimental results that exhibits the practical gain of such methods.
Catalogs.pdf (159.7 Ko) Télécharger le fichier
Format : Figure, Image
inria-00560400 , version 1 (28-01-2011)
Luca Castelli Aleardi, Olivier Devillers, Abdelkrim Mebarki. Catalog Based Representation of 2D triangulations. International Journal of Computational Geometry and Applications, 2011, 21 (4), pp.393-402. ⟨10.1142/S021819591100372X⟩. ⟨inria-00560400⟩
289 Consultations
302 Téléchargements
