News image annotation on a large parallel text-image corpus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pierre Tirilly
Patrick Gros
In this paper, we present a multimodal parallel text-image corpus, and propose an image annotation method that exploits the textual information associated with images. Our corpus contains news articles composed of a text, images and image captions, and is significantly larger than the other news corpora proposed in image annotation papers (27,041 articles and 42,568 captionned images). In our experiments, we use the text of the articles as a textual information source to annotate images, and image captions as a groundtruth to evaluate our annotation algorithm. Our annotation method identifies relevant named entities in the texts, and associates them with high-level visual concepts detected in the images (in this paper, faces and logos). The named entities most suited to image annotation are selected using an unsupervised score based on their statistics, inspired from the weights used in information retrieval. Our experiments show that, although it is very simple, our annotation method achieves an acceptable accuracy on our real-world news corpus.
Fichier non déposé
inria-00561763 , version 1 (01-02-2011)
  • HAL Id : inria-00561763 , version 1
Pierre Tirilly, Vincent Claveau, Patrick Gros. News image annotation on a large parallel text-image corpus. 7th Language Resources and Evaluation Conference, LREC'10, ELRA, May 2010, Valletta, Malta. ⟨inria-00561763⟩
290 Consultations
0 Téléchargements
