New interface
Conference papers
Time and Level Localization Curves for a Regularly-Spaced Octagon Loudspeaker Array
Abstract : Multichannel microphone array designs often use the localisation curves that have been derived for 2-0 stereophony. Previous studies showed that side and rear perception of phantom image locations require somewhat different curves. This paper describes an experiment conducted to determine localisation curves using an octagonal loudspeaker setup. Various signals with a range of interchannel time and level differences were produced between pairs of adjacent loudspeakers, and subjects were asked to evaluate the perceived sound event's direction and its locatedness. The results showed that the curve for the side pairs of adjacent loudspeakers are significantly different to the front and rear pairs. The resulting curves can be used to derive suitable microphone techniques for this loudspeaker setup.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00563362
Contributor : Laurent S. R. Simon Connect in order to contact the contributor
Submitted on : Friday, February 4, 2011 - 4:12:37 PM
Last modification on : Friday, March 11, 2022 - 3:08:08 PM
Identifiers
  • HAL Id : inria-00563362, version 1
Citation
Laurent S. R. Simon, Russell Mason. Time and Level Localization Curves for a Regularly-Spaced Octagon Loudspeaker Array. Audio Engineering Society 128th convention, May 2010, London, United Kingdom. ⟨inria-00563362⟩
Share
Metrics
Record views
29
