Compiling multithreaded Java bytecode for distributed execution
Our work combines Java compilation to native code with a run-time library that executes Java threads in a distributed-memory environment. This allows a Java programmer to view a cluster of processors as executing a single Java virtual machine. The separate processors are simply resources for executing Java threads with true concurrency and the run-time system provides the illusion of a shared memory on top of the private memories of the processors. The environment we present is available on top of several UNIX systems and can use a large variety of network protocols thanks to the high portability of its run-time system. To evaluate our approach, we compare serial C, serial Java, and multithreaded Java implementations of a branch-and-bound solution to the minimal-cost map-coloring problem. All measurements have been carried out on two platforms using two different network protocols: SISCI/SCI and MPI-BIP/Myrinet.
Origin : Publisher files allowed on an open archive
