New interface
Reports (Research report)
Learning the Direction of a Sound Source Using Head Motions and Spectral Features
Antoine Deleforge 1 Radu Horaud 1
1 PERCEPTION - Interpretation and Modelling of Images and Videos
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : In this paper we address the problem of localizing a sound-source by combining binaural or monaural spectral features with head movements. Based on a number of psychophysical and behavioral studies suggesting that the problem of spatial hearing is both listener-dependent and dynamic, we propose to address the problem at hand within the framework of unsupervised learning. More precisely, our method is able to retrieve an intrinsic low-dimensional parameterization from the high-dimensional spectral representation of the acoustic input. We address both binaural and monaural spatial localization with both static and dynamic cues. We show that the recovered low-dimensional representations are homeomorphic to the two-dimensional manifold associated with the motor states of a robotic head with two rotational degrees of freedom. We describe the experimental setup and protocols allowing us to gather acoustic data sets with ground truth for both the emitter-to-listener directions and precise head motions. We validate our method using extensive experiments that consist in classifying acoustic vectors from a test set, based on manifold learning with a different training set. Our method strongly contrasts with current approaches in sound localization because it puts forward the role of learning.
Document type :
Complete list of metadata
Cited literature [40 references]  Display  Hide  Download
https://hal.inria.fr/inria-00564708
Contributor : Antoine Deleforge Connect in order to contact the contributor
Submitted on : Wednesday, February 9, 2011 - 4:56:32 PM
Last modification on : Thursday, October 27, 2022 - 4:03:08 AM
Long-term archiving on: : Tuesday, November 6, 2012 - 1:46:00 PM
File
RR-7529.pdf
Identifiers
  • HAL Id : inria-00564708, version 1
Citation
Antoine Deleforge, Radu Horaud. Learning the Direction of a Sound Source Using Head Motions and Spectral Features. [Research Report] RR-7529, INRIA. 2011, pp.29. ⟨inria-00564708⟩
Share
Metrics
Record views
409
Files downloads
259
