BSS_EVAL Toolbox User Guide -- Revision 2.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2005
Cédric Févotte
Emmanuel Vincent
This document is meant to help you use the BSS EVAL toolbox, which implements some criteria for performance measurement in (blind) source separation. The toolbox -- which is distributed under the terms of the GNU GENERAL PUBLIC LICENSE as a set of Matlab routines --can be downloaded at the address http://www.irisa.fr/metiss/bss_eval/. The purpose of this toolbox is to measure the performance of various source separation algorithms in an evaluation framework where the original sources, and perhaps even the noise that perturbed the mixture, are available for comparison.
PI-1706.pdf (186.91 Ko) Télécharger le fichier
inria-00564760 , version 1 (09-02-2011)
  • HAL Id : inria-00564760 , version 1
Cédric Févotte, Rémi Gribonval, Emmanuel Vincent. BSS_EVAL Toolbox User Guide -- Revision 2.0. [Technical Report] 2005, pp.19. ⟨inria-00564760⟩
1669 Consultations
5279 Téléchargements
