Nonlinear approximation with bi-framelets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We study the approximation in Lebesgue spaces of wave- let bi-frame systems given by translations and dilations of a finite set of generators. A complete characterization of the approximation spaces associated with best m-term approximation of wavelet bi-framelet systems is given. The characterization depends, in general, on the number of vanishing moments of the generators. However, in some cases it is possible to get rid of this restriction, but at the price of replacing the canonical expansion by another linear expansion. This is done by expanding a suitable wavelet in the wavelet bi-frame system.
gatlinburg.pdf (143.83 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00564761 , version 1 (07-03-2011)
  • HAL Id : inria-00564761 , version 1
Lasse Borup, Rémi Gribonval, Morten Nielsen. Nonlinear approximation with bi-framelets. Approximation Theory XI, 2004, Gatlinburg, United States. pp.101-112. ⟨inria-00564761⟩
193 Consultations
115 Téléchargements
