Workload balancing and throughput optimization for heterogeneous systems subject to failures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
In this report, we study the problem of optimizing the throughput of applications for heterogeneous platforms subject to failures. The considered applications are composed of a sequence of consecutive tasks linked as a linear graph (pipeline), with a type associated to each task. The challenge is to specialize the machines of a target platform to process only one task type, given that every machine is able to process all the types before being specialized, to avoid costly context or setup changes. Each instance can thus be performed by any machine specialized in its type and the workload of the system can be shared among a set of specialized machines. For identical machines, we prove that an optimal solution can be computed in polynomial time. However, the problem becomes NP-hard when two machines can compute the same task type at different speeds. Several polynomial time heuristics are presented for the most realistic specialized settings. Experimental results show that the best heuristics obtain a good throughput, much better than the throughput obtained with a random mapping, and close to the optimal throughput in the particular cases on which the optimal throughput can be computed.
Dans ce rapport, nous étudions le problème de l'optimisation du débit d'applications de type pipeline dans un environnement hétérogène sujet à des pannes. Les applications sont constituées d'un ensemble de tâches consécu\-tives typées et organisées selon une chaîne linéaire ou pipeline. Le but est ici de spécialiser les machines de la plate-forme d'exécution afin qu'elles ne traitent qu'un seul type de tâches, sachant qu'au départ elles peuvent exécuter tous les types. Cela permet d'éviter des reconfigurations coûteuses entre tâches de types différents sur une même machine. Ainsi, les instances d'une même tâche peuvent être distribuées sur plusieurs machines spécialisées pour le type de cette tâche, ce qui permet une répartition de la charge du système sur un ensemble de machines spécialisées. Lorsque la plate-forme est composée de machines identiques, nous prouvons qu'une solution optimale peut être trouvée en temps polynomial. Par contre, le problème devient NP-complet dès lors que deux machines peuvent traiter une même tâche à des vitesses différentes. Ce faisant, plusieurs heuristiques sont présentées dans le cas le plus réaliste d'un système spécialisé. Les résultats expérimentaux montrent que les meilleures heuristiques obtiennent de bons résultats en terme de débit, meilleurs qu'avec une allocation aléatoire, et que les débits atteints sont très proches des débits optimaux dans les cas particuliers pour lesquels une solution optimale peut être calculée.
RR-7532.pdf (388.92 Ko) Télécharger le fichier
inria-00565151 , version 1 (11-02-2011)
  • HAL Id : inria-00565151 , version 1
Anne Benoit, Alexandru Dobrila, Jean-Marc Nicod, Laurent Philippe. Workload balancing and throughput optimization for heterogeneous systems subject to failures. [Research Report] RR-7532, INRIA. 2011, pp.22. ⟨inria-00565151⟩
161 Consultations
174 Téléchargements
