Threshold Cryptosystems Secure against Chosen-Ciphertext Attacks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Semantic security against chosen-ciphertext attacks (IND-CCA) is widely believed as the correct security level for public-key encryption scheme. On the other hand, it is often dangerous to give to only one people the power of decryption. Therefore, threshold cryptosystems aimed at distributing the decryption ability. However, only two efficient such schemes have been proposed so far for achieving IND-CCA. Both are El Gamal-like schemes and thus are based on the same intractability assumption, namely the Decisional Diffie-Hellman problem. In this article we rehabilitate the twin-encryption paradigm proposed by Naor and Yung to present generic conversions from a large family of (threshold) IND-CPA scheme into a (threshold) IND-CCA one in the random oracle model. An efficient instantiation is also proposed, which is based on the Paillier cryptosystem. This new construction provides the first example of threshold cryptosystem secure against chosen-ciphertext attacks based on the factorization problem. Moreover, this construction provides a scheme where the ?homomorphic properties? of the original scheme still hold. This is rather cumbersome because homomorphic cryptosystems are known to be malleable and therefore not to be CCA secure. However, we do not build a ?homomorphic cryptosystem?, but just keep the homomorphic properties.
asia01b.pdf (217.37 Ko) Télécharger le fichier
inria-00565272 , version 1 (11-02-2011)
Pierre-Alain Fouque, David Pointcheval. Threshold Cryptosystems Secure against Chosen-Ciphertext Attacks. Advances in Cryptology - ASIACRYPT 2001, 7th International Conference on the Theory and Application of Cryptology and Information Security, 2001, Gold Coast, Australia. pp.351-368, ⟨10.1007/3-540-45682-1_21⟩. ⟨inria-00565272⟩
115 Consultations
514 Téléchargements
