Not all parents are equal for MO-CMA-ES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Steady State variants of the Multi-Objective Covariance Matrix Adaptation Evolution Strategy (SS-MO-CMA-ES) generate one offspring from a uniformly selected parent. Some other parental selection operators for SS-MO-CMA-ES are investigated in this paper. These operators involve the definition of multi-objective rewards, estimating the expectation of the offspring survival and its Hypervolume contribution. Two selection modes, respectively using tournament, and inspired from the Multi-Armed Bandit framework, are used on top of these rewards. Extensive experimental validation comparatively demonstrates the merits of these new selection operators on unimodal MO problems.
emo2011.pdf (1.38 Mo) Télécharger le fichier
inria-00565282 , version 1 (11-02-2011)
  • HAL Id : inria-00565282 , version 1
Ilya Loshchilov, Marc Schoenauer, Michèle Sebag. Not all parents are equal for MO-CMA-ES. Evolutionary Multi-Criterion Optimization 2011 (EMO 2011), Apr 2011, Ouro Preto, Brazil. pp.31-45. ⟨inria-00565282⟩
128 Consultations
308 Téléchargements
