IP Version 6 Addressing Architecture, RFCDraft Standard), vol.4291, 2006. ,
DOI : 10.17487/rfc4291
OSPF for IPv6, RFC, vol.5340, 2008. ,
RIPng for IPv6, RFC, vol.2080, 1997. ,
DOI : 10.17487/rfc2080
Neighbor Discovery for IP version 6 (IPv6), RFC, vol.4861, 2007. ,
Optimized Link State Routing Protocol (OLSR), RFC, vol.3626, 2003. ,
DOI : 10.17487/rfc3626
URL : https://hal.archives-ouvertes.fr/inria-00471712
Multicast Listener Discovery Version 2 (MLDv2) for IPv6, RFC, vol.3810, 2004. ,
DOI : 10.17487/rfc3810
Mobility Support in IPv6, RFC, vol.3775, 2004. ,
DOI : 10.17487/rfc3775
Network Mobility Route Optimization Problem Statement, RFC, vol.4888, 2007. ,
DOI : 10.17487/rfc4888
Network Mobility Route Optimization Solution Space Analysis, RFC, vol.4889, 2007. ,
DOI : 10.17487/rfc4889
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.374.296
Automotive Industry Requirements for NEMO Route Optimization Work in progress, draft-ietf-mext-nemo-ro-automotive-req-02, 2009. ,
NEMO Route Optimization Requirements for Operational Use in Aeronautics and Space Exploration Mobile Networks, 2007. ,
Multiple Care-of Addresses Registration, pp.6-11, 2008. ,
DOI : 10.17487/rfc5648
ORC: optimized route cache management protocol for network mobility, 10th International Conference on Telecommunications, 2003. ICT 2003., pp.1194-1200, 2003. ,
DOI : 10.1109/ICTEL.2003.1191606
Route Optimization Scheme based on Path Control Header, 2004. ,
Correspondent Router based Route Optimisation for NEMO (CRON), 2008. ,
Routing Optimization for Nested Mobile Networks, IEICE Transactions on Communications, vol.89, issue.10, 2006. ,
DOI : 10.1093/ietcom/e89-b.10.2786
IETF, draft-thubert-nemo-global-haha-02, 2006. ,
Hierarchical Mobile IPv6 Mobility Management (HMIPv6), RFC, vol.4140, 2005. ,
DOI : 10.17487/rfc4140
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.417.7303
Vehicle Communication Experiment Environment with MANET and NEMO, 2007 International Symposium on Applications and the Internet Workshops, 2007. ,
DOI : 10.1109/SAINT-W.2007.104
Design of vehicle network, Proceedings of the 2nd ACM international workshop on Vehicular ad hoc networks , VANET '05, 2005. ,
DOI : 10.1145/1080754.1080768
Optimized Inter-Vehicle Communications Using NEMO and MANET (Invited Paper) The Second International Workshop on Vehicle-to-Vehicle Communications, 2006. ,
VARON: Vehicular Ad hoc Route Optimisation for NEMO, Computer Communications, vol.30, issue.8, pp.1765-1784, 2007. ,
DOI : 10.1016/j.comcom.2007.02.011
IPv6 Reverse Routing Header and its application to Mobile Networks IETF, draft-thubert-nemo-reverse-routing-header- 07, 2007. ,
Secure Nested Tunnels Optimization using Nested Path Information, 2003. ,
Securing Nested Tunnels Optimization with Access Router Option IETF, draft-ng-nemo-access-router-option-01, 2004. ,
Extended Network Mobility Support, 2003. ,
Route Optimization for Mobile Nodes in Mobile Network based on Prefix Delegation, p.2, 2004. ,
ND-Proxy based Route and DNS Optimizations for Mobile Nodes in Mobile Network, p.2, 2004. ,
The Design Consideration of Correspondent Router. IETF Work in progress, draft-wakikawa-mext-cr-consideration-00, 2008. ,
Problem statement and requirements for manemo, 2007. ,
IETF, draft-mccarthy-manemo-configuration-problems-00, 2007. ,
IPv6 Prefix Options for Dynamic Host Configuration Protocol (DHCP) version 6, RFC, vol.3633, 2003. ,
DOI : 10.17487/rfc3633
Neighbor Discovery for IP Version 6 (IPv6) RFC 2461 (Draft Standard), 1998. ,
