Tending Fire ? Coping With America's Wildland Fires, 2004. ,
REPRESENTING MODEL UNCERTAINTY IN WEATHER AND CLIMATE PREDICTION, Annual Review of Earth and Planetary Sciences, vol.33, issue.1, pp.163-193, 2005. ,
DOI : 10.1146/annurev.earth.33.092203.122552
Encyclopedia of Atmospheric Sciences, chapter Wildfire Weather, pp.586-588, 2003. ,
Forest fires ? Behavior and ecological effects, chapter Coupling atmospheric and fire models, pp.257-302, 2001. ,
The impact of changing the surface fire spread model, JFSP, 2003. ,
FARSITE: Fire area simulator-model development and evaluation, 1998. ,
FOREST FIRE SPREAD MODELS: THE LOCAL QUASI-EQUILIBRIUM APPROACH, Combustion Science and Technology, vol.45, issue.12, pp.115-117, 2006. ,
DOI : 10.1080/00102200490255343
Fronts propagating with curvature-dependent speed: Algorithms based on Hamilton-Jacobi formulations, Journal of Computational Physics, vol.79, issue.1, pp.12-49, 1988. ,
DOI : 10.1016/0021-9991(88)90002-2
Level set methods and fast marching methods, 1999. ,
Forest fires ? Behavior and ecological effects, chapter Wind-aided fire spread, pp.171-223, 2001. ,
Wind-Aided Firespread Across Arrays of Discrete Fuel Elements. II. Experiment, Combustion Science and Technology, vol.72, issue.4-6, pp.261-289, 1991. ,
DOI : 10.1093/forestry/44.2.155
Generalized solutions of Hamilton-Jacobi equations, Research Notes in Mathematics #69. Pitman, 1982. ,
Viscosity solutions of Hamilton-Jacobi equations. Transactions of the, pp.1-42, 1983. ,
SLIC (Simple Line Interface Calculation), Fith International Conference on Numerical Methods in Fluid Dynamics, pp.330-340, 1976. ,
DOI : 10.1007/3-540-08004-X_336
A Fast Level Set Method for Propagating Interfaces, Journal of Computational Physics, vol.118, issue.2, pp.269-277, 1995. ,
DOI : 10.1006/jcph.1995.1098
A fast marching level set method for monotonically advancing fronts., Proceedings of the National Academy of Sciences, pp.591-1595, 1996. ,
DOI : 10.1073/pnas.93.4.1591
Two approximations of solutions of Hamilton-Jacobi equations, Mathematics of Computation, vol.43, issue.167, pp.1-19, 1984. ,
DOI : 10.1090/S0025-5718-1984-0744921-8
Approximation schemes for viscosity solutions of Hamilton-Jacobi equations, Journal of Differential Equations, vol.59, issue.1, pp.1-43, 1985. ,
DOI : 10.1016/0022-0396(85)90136-6
High-Order Essentially Nonoscillatory Schemes for Hamilton???Jacobi Equations, SIAM Journal on Numerical Analysis, vol.28, issue.4, pp.907-922, 1991. ,
DOI : 10.1137/0728049
URL : http://www.dtic.mil/get-tr-doc/pdf?AD=ADA219518
Ordered upwind methods for static Hamilton-Jacobi equations, Proceedings of the National Academy of Sciences, pp.69-11074, 2001. ,
DOI : 10.1073/pnas.201222998
Modeling the growth of Si-based nanofilms by coupling the boundary contour method and level set Multivac, Proceedings of the Tenth international conference on composite engineering, pp.575-576, 2003. ,
Active contours without edges, IEEE Transactions on Image Processing, vol.10, issue.2, pp.266-277, 2001. ,
Numerical Schemes for the Hamilton???Jacobi and Level Set Equations on Triangulated Domains, Journal of Computational Physics, vol.145, issue.1, pp.1-40, 1998. ,
DOI : 10.1006/jcph.1998.6007
The Fast Construction of Extension Velocities in Level Set Methods, Journal of Computational Physics, vol.148, issue.1, pp.2-22, 1998. ,
DOI : 10.1006/jcph.1998.6090
Bushfires in Australia, 1978. ,
