Folded Paper Geometry from 2D Pattern and 3D Contour - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Folded paper exhibits very characteristic shapes, due to the presence of sharp folds and to exact isometry with a given planar pattern. Therefore, none of the physically-based simulators developed so far can handle paper-like material. We propose a purely geometric solution to generate static folded paper geometry from a 2D pattern and a 3D placement of its contour curve. Fold lines are explicitly identified and used to control a recursive, local subdivision process, leading to an efficient procedural modeling of the surface through a fold-aligned mesh. Contrary to previous work, our method generates paper-like surfaces with sharp creases while maintaining approximate isometry with the input pattern.
Mots clés
RCHT_EG11.pdf (1.1 Mo) Télécharger le fichier
RCHT_EG11.mp4 (30.17 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00567408 , version 1 (21-02-2011)
  • HAL Id : inria-00567408 , version 1
Damien Rohmer, Marie-Paule Cani, Stefanie Hahmann, Boris Thibert. Folded Paper Geometry from 2D Pattern and 3D Contour. Eurographics 2011 (short paper), European Association for Computer Graphics, Apr 2011, Llandudno, United Kingdom. pp.21-24. ⟨inria-00567408⟩
1209 Consultations
1925 Téléchargements
