Deployment Experience with Low Power Lossy Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Cédric Adjih
Emmanuel Baccelli
Philippe Jacquet
Pascale Minet
Georg Wittenburg
  • Fonction : Auteur
  • PersonId : 892529
Protocols that are to be employed in the context of the Internet of Things (IoT) have to meet a wide variety of application-specific requirements. In this report, we reflect on recent experiences, gained from several real-world deployments in which we have participated, which use low power, embedded networking devices. We discuss the lessons learned from these deployments, with an emphasis on questions affecting the IP layer and, in particular, on the routing protocols for these networks. We point out open issues and possible directions of future work for such routing protocols.
RR-7551.pdf (214.72 Ko) Télécharger le fichier
inria-00567993 , version 1 (23-02-2011)
  • HAL Id : inria-00567993 , version 1
Cédric Adjih, Emmanuel Baccelli, Philippe Jacquet, Pascale Minet, Matthias Philipp, et al.. Deployment Experience with Low Power Lossy Wireless Sensor Networks. [Research Report] RR-7551, INRIA. 2011. ⟨inria-00567993⟩
328 Consultations
183 Téléchargements
