Vision-based guidance and control of a hovering vehicle in unknown, GPS-denied environments, 2009 IEEE International Conference on Robotics and Automation, 2009. ,
DOI : 10.1109/ROBOT.2009.5152680
Non linear Observability and Identifiability: General Theory and a Case Study of a Kinetic Model, 2004. ,
Fast Ego-motion Estimation with Multi-rate Fusion of Inertial and Vision, The International Journal of Robotics Research, vol.26, issue.6, pp.577-589, 2007. ,
DOI : 10.1177/0278364907079283
Vision based MAV navigation in unknown and unstructured environments, 2010 IEEE International Conference on Robotics and Automation, 2010. ,
DOI : 10.1109/ROBOT.2010.5509920
Building a Robust Implementation of Bearing-only Inertial SLAM for a UAV, Journal of Field Robotics, vol.15, issue.1-2, pp.113-143, 2007. ,
DOI : 10.1002/rob.20178
A computer algorithm for reconstructing a scene from two projections, Nature, vol.293, p.133135, 1981. ,
An Introduction to Inertial and Visual Sensing, The International Journal of Robotics Research, vol.26, issue.6, pp.519-535, 2007. ,
DOI : 10.1177/0278364907079279
MonoSLAM: Real-Time Single Camera SLAM, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.6, pp.1052-1067, 2007. ,
DOI : 10.1109/TPAMI.2007.1049
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.454.5419
Editorial: Special Issue: 2nd Workshop on Integration of Vision and Inertial Sensors, The International Journal of Robotics Research, vol.26, issue.6, pp.515-517, 2007. ,
DOI : 10.1177/0278364907079903
SIFT Based Graphical SLAM on a Packbot, Field and Service Robotics, 2007. ,
Simultaneous Motion and Structure Estimation by Fusion of Inertial and Vision Data, The International Journal of Robotics Research, vol.26, issue.6, pp.591-605, 2007. ,
DOI : 10.1177/0278364907080058
In defense of the eight-point algorithm, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.19, issue.6, p.580593, 1997. ,
DOI : 10.1109/34.601246
Nonlinear Controllability and Observability , Transaction On Automatic Control, pp.22-728, 1977. ,
Modeling and Calibration of Inertial and Vision Sensors, The International Journal of Robotics Research, vol.22, issue.11, pp.2-3, 2010. ,
DOI : 10.1145/358669.358692
Real-time implementation of airborne inertial-SLAM, Robotics and Autonomous Systems, vol.55, issue.1, pp.62-71, 2007. ,
DOI : 10.1016/j.robot.2006.06.006
Relative Pose Calibration Between Visual and Inertial Sensors, The International Journal of Robotics Research, vol.26, issue.6, pp.561-575, 2007. ,
DOI : 10.1177/0278364907079276
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.379.7850
A simple learning strategy for high-speed quadrocopter multi-flips, 2010 IEEE International Conference on Robotics and Automation, 2010. ,
DOI : 10.1109/ROBOT.2010.5509452
Removing scale biases and ambiguity from 6DoF monocular SLAM using inertial, 2008 IEEE International Conference on Robotics and Automation, 2008. ,
DOI : 10.1109/ROBOT.2008.4543778
Continuous Symmetries and Observability Properties in Autonomous Navigation, Internal Research Report ,
URL : https://hal.archives-ouvertes.fr/inria-00421233
State Estimation Based on the Concept of Continuous Symmetry and Observability Analysis: The Case of Calibration, IEEE Transactions on Robotics, vol.27, issue.2 ,
DOI : 10.1109/TRO.2011.2109210
URL : https://hal.archives-ouvertes.fr/hal-00578795
Closed-Form Solution for Attitude and Speed Determination by Fusing Monocular Vision and Inertial Sensor Measurements, accepted for presentation at ICRA, 2011. ,
A Kalman Filter-Based Algorithm for IMU-Camera Calibration: Observability Analysis and Performance Evaluation, IEEE Transactions on Robotics, vol.24, issue.5, pp.1143-1156 ,
DOI : 10.1109/TRO.2008.2004486
A Multi-State Constrained Kalman filter for Vision-aided Inertial Navigation, Proc. 2007 IEEE International Conference on Robotics and Automation (ICRA'07), pp.10-14 ,
Vision-Aided Inertial Navigation for Spacecraft Entry, Descent, and Landing, IEEE Transactions on Robotics, vol.25, issue.2, pp.264-280 ,
DOI : 10.1109/TRO.2009.2012342
An efficient solution to the five-point relative pose problem, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.6, pp.756-770, 2004. ,
DOI : 10.1109/TPAMI.2004.17
Reduction of inherent ambiguities in structure from motion problem using inertial data, Proceedings 2000 International Conference on Image Processing (Cat. No.00CH37101), 2000. ,
DOI : 10.1109/ICIP.2000.900930
A toolbox for easy calibrating omnidirectional cameras, IEEE International Conference on Inteligent Robots and Systems, 2006. ,
Motion Estimation from Image and Inertial Measurements, The International Journal of Robotics Research, vol.23, issue.12, 2004. ,
DOI : 10.1177/0278364904045593
Fusing Low-Cost Image and Inertial Sensors for Passive Navigation, Navigation, vol.Vol II, issue.6, 2007. ,
DOI : 10.1002/j.2161-4296.2007.tb00391.x
Camera-aided inertial navigation using epipolar points, Proceedings of PLANS, 2010. ,
24 7.1.1 Single Feature, p.25 ,
26 7.2.1 Single Feature 26 7.2.2 Single feature; exploiting additional information, p.29 ,
