Physical expander in Virtual Tree Overlay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose a new construction of constantdegree expanders motivated by their application in P2P overlay networks and in particular in the design of robust trees overlay. Our key result can be stated as follows. Consider a complete binary tree T and construct a random pairing Π between leaf nodes and internal nodes. We prove that the graph GΠ obtained from T by contracting all pairs (leaf-internal nodes) achieves a constant node expansion with high probability. The use of our result in improving the robustness of tree overlays is straightforward. That is, if each physical node participating to the overlay manages a random pair that couples one virtual internal node and one virtual leaf node then the physical-node layer exhibits a constant expansion with high probability. We encompass the difficulty of obtaining this random tree virtualization by proposing a local, selforganizing and churn resilient uniformly-random pairing algorithm with O(log2 n) running time. Our algorithm has the merit to not modify the original tree virtual overlay (we just control the mapping between physical nodes and virtual nodes). Therefore, our scheme is general and can be applied to a large number of tree overlay implementations. We validate its performances in dynamic environments via extensive simulations.
robust-tree.pdf (316.41 Ko) Télécharger le fichier
inria-00569098 , version 1 (24-02-2011)
Taisuke Izumi, Maria Potop-Butucaru, Mathieu Valero. Physical expander in Virtual Tree Overlay. DISC 2011 - 25th International Symposium on Distributed Computing, Sep 2011, Rome, Italy. pp.82-96, ⟨10.1007/978-3-642-24100-0_6⟩. ⟨inria-00569098⟩
219 Consultations
173 Téléchargements
