New interface
Reports (Research report)
An ExpSpace Tableau-based Algorithm for SHOIQ
Abstract : In this work, we propose an ExpSpace tableau-based algorithm for deciding consistency of a knowledge base in the description logic SHOIQ. The construction of this algorithm is founded on the standard tableau-based method for SHOIQ and the technique used for designing a NExpTime algorithm for the two-variable fragment of first-order logic with counting quantifiers C^2.
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/inria-00570161
Contributor : Chan Le Duc Connect in order to contact the contributor
Submitted on : Saturday, June 2, 2012 - 11:38:07 AM
Last modification on : Wednesday, October 26, 2022 - 8:16:12 AM
Long-term archiving on: : Thursday, December 15, 2016 - 10:42:04 AM
File
optimal-shoiq.pdf
Identifiers
  • HAL Id : inria-00570161, version 3
Citation
Chan Le Duc, Myriam Lamolle, Olivier Curé. An ExpSpace Tableau-based Algorithm for SHOIQ. [Research Report] 2012, pp.36. ⟨inria-00570161v3⟩
Share
Metrics
Record views
263
Files downloads
341
