Error analysis of Jacobi derivative estimators for noisy signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Algorithms Année : 2011
Recent algebraic parametric estimation techniques (see \cite{garnier,mfhsr}) led to point-wise derivative estimates by using only the iterated integral of a noisy observation signal (see \cite{num0,num}). In this paper, we extend such differentiation methods by providing a larger choice of parameters in these integrals: they can be reals. For this, %as in \cite{num0,num}, the extension is done via a truncated Jacobi orthogonal series expansion. Then, the noise error contribution of these derivative estimations is investigated: after proving the existence of such integral with a stochastic process noise, their statistical properties (mean value, variance and covariance) are analyzed. In particular, the following important results are obtained: \begin{description} \item[$a)$] the bias error term, due to the truncation, can be reduced by tuning the parameters, \item[$b)$] such estimators can cope with a large class of noises for which the mean and covariance are polynomials in time (with degree smaller than the order of derivative to be estimated), \item[$c)$] the variance of the noise error is shown to be smaller in the case of negative real parameters than it was in \cite{num0,num} for integer values. \end{description} Consequently, these derivative estimations can be improved by tuning the parameters according to the here obtained knowledge of the parameters' influence on the error bounds.
finale_corrige_V1.pdf (588.18 Ko) Télécharger le fichier
inria-00573270 , version 1 (03-03-2011)
Da-Yan Liu, Olivier Gibaru, Wilfrid Perruquetti. Error analysis of Jacobi derivative estimators for noisy signals. Numerical Algorithms, 2011, 58 (1), pp.53-83. ⟨10.1007/s11075-011-9447-8⟩. ⟨inria-00573270⟩
377 Consultations
349 Téléchargements
