Non negative sparse representation for Wiener based source separation with a single sensor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We propose a new method to perform the separation of two sound sources from a single sensor. This method generalizes the Wiener filtering with locally stationary, non gaussian, parametric source models. The method involves a learning phase for which we propose three different algorithm. In the separation phase, we use a sparse non negative decomposi- tion algorithm of our own. The algorithms are evaluated on the separation of real audio data.
06-00613.pdf (105.59 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00574784 , version 1 (08-03-2011)
Laurent Benaroya, Lorcan Mcdonagh, Frédéric Bimbot, Rémi Gribonval. Non negative sparse representation for Wiener based source separation with a single sensor. IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP 2003), Apr 2003, Hong-Kong, Hong Kong SAR China. pp.VI/613--VI/616, ⟨10.1109/ICASSP.2003.1201756⟩. ⟨inria-00574784⟩
358 Consultations
568 Téléchargements
