Analysis of Sound Signals with High Resolution Matching Pursuit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1996
Sound recordings include transients and sustained parts. Their analysis with a basis expansion is not rich enough to represent efficiently all such components. Pursuit algorithms choose the decomposition vectors depending upon the signal properties. The dictionary among which these vectors are selected is much larger than a basis. Matching pursuit is fast to compute, but can provide coarse representations. Basis pursuit gives a better representation but is very expensive in terms of calculation time. This paper develops a high resolution matching pursuit: it is a fast, high time-resolution, time-frequency analysis algorithm, that makes it likely to be used far musical applications
tfts96.pdf (152.76 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00576196 , version 1 (13-03-2011)
Rémi Gribonval, Emmanuel Bacry, Stéphane Mallat, Philippe Depalle, Xavier Rodet. Analysis of Sound Signals with High Resolution Matching Pursuit. Proc. IEEE Symp. Time-Freq. and Time-Scale Anal. (TFTS'96), Jun 1996, Paris, France. pp.125-128, ⟨10.1109/TFSA.1996.546702⟩. ⟨inria-00576196⟩
163 Consultations
382 Téléchargements
