On the quasi-greedy property and uniformly bounded orthonormal systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We derive a necessary condition for a uniformly bounded orthonormal basis for L2(\Omega), \Omega a probability space, to be quasi-greedy in Lp(\Omega), p \neq 2, and then use this condition to prove that many classical systems, such as the trigonometric system and Walsh system, fail to be quasi-greedy in Lp, p \neq 2, i.e., thresholding is not well-behaved in Lp, p \neq 2, for such systems.
R-2003-09.pdf (164.26 Ko) Télécharger le fichier
inria-00576212 , version 1 (13-03-2011)
  • HAL Id : inria-00576212 , version 1
Rémi Gribonval, Morten Nielsen. On the quasi-greedy property and uniformly bounded orthonormal systems. [Research Report] R-2003-09, 2003. ⟨inria-00576212⟩
161 Consultations
81 Téléchargements
